Blue Efficiency Badge Removal
Old Feb 1, 2018 | 06:35 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
I would like to remove the Blue Efficiency badges from my 2012 E550 Cab and replace with V8 biturbo badges. I was under the impression the badges were attached with double sided tape. I went out tonight with my dental floss to try and remove the badges and I couldn't get the dental floss to pass through behind the badge. I gently used a trim tool to pry up the badge a bit and it appears there are barrel clips. I decided to stop and not force it until I did more research. Am I mistaken about the barrel clips?
Old Feb 2, 2018 | 08:40 AM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
No clips on my 2012 E550 Coupe. I used a heat gun as well when I removed my Blue Efficiency Badge.
Old Feb 2, 2018 | 11:49 AM
Davery's Avatar
I have not had anyone tell me the badge was attached with barrel clips, but yet it appears to be on mine. Perhaps I am mistaken and I am seeing bit of glue residue that looks like a barrel clip pin. I didn't want to force it until I did a bit more research.
Old Feb 2, 2018 | 11:57 AM
konigstiger's Avatar
'71 Pinto
EPC shows no clips, you can view front/rear here: http://евроавто.рф/parts/used/model=2175050928/6900107
Old Feb 5, 2018 | 07:11 AM
Davery's Avatar
Thanks for the info. I finally removed the badges, but have some adhesive residue remaining. I have tried Goo Gone and Windex, but it is still there. Ideas?
Old Feb 5, 2018 | 09:23 AM
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Try some "Skin So Soft". Worked for me. Ask your wife/girl friend. She'll know what it is.
Old Feb 5, 2018 | 01:51 PM
Ken B's Avatar
2012 E550C, 2017 E300
Your wife uses a skin softener that dissolves adhesives?
Old Feb 5, 2018 | 03:04 PM
pdeacon's Avatar
Sounds strange when you put it that way....but it works!
