2014 A207 rear seat removal
Old May 13, 2018 | 12:18 PM
Joe042863's Avatar
2014 e350 Cabriolet
Does anyone know how to remove the rear seat bottom so I can remove the seat back to get to the seat belt tensioner?
Old May 13, 2018 | 08:53 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Seat belts usually have very long warranties. Shouldn’t the dealer be fixing this? Is this a project for DYIers?
Old May 22, 2018 | 11:34 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 22, 2018 | 01:10 PM
Joe042863's Avatar
2014 e350 Cabriolet
Thumbs up
See attachments.
Thank You vary much for the attached PDF files. One last ? Would you know if there is the possibility of triggering Air bag Deployment while removing seat belt tensioner and when disconnecting ground wire of battery will I lose any functions of vehicle when it is reattached?
Old May 22, 2018 | 01:38 PM
'71 Pinto
Recommend checking SRS with SDS (MB diagnostics) after replacement. Should not loose any functions after disconnecting battery.
Old Mar 1, 2021 | 11:08 AM
Simon Judd's Avatar
A207 2015 e220 bluetec cabriolet
A207 2015 remove back seat clips help please
anyone know how these clips numbered 6 release spent an hour now and don't want to break anything but can't get them free
Old Nov 24, 2021 | 12:37 AM
The_Grimy_One's Avatar
2004 E320 Wagon / 2013 E550 Coupe
Did you ever figure this out?
Old Nov 24, 2022 | 03:35 PM
tvsrsltd's Avatar
Mercedes-Benz e350 convertible
hi
use a very long flat head screw driver and insert it down the side of the fitting and pry outwards towards the wheel arch whilst pulling on the lower part of the back rear towards you. Then repeat on the other side then lift whole back rest upwards then pull top half towards yourself to allow lower prongs to not get caught. Hey presto. Your welcome 🙏
