Aftermarket Radio
Old Aug 31, 2018 | 07:08 PM
  #51
dmndE550cp's Avatar
2011 E550 Coupe
Update 2:
My issue was a CAN bus connection issue. Just had to swap the A/B with A and B connections until I had the right right connection. I believe I ended up with A/B to B and ‘cap’ A on A.
Installation overall was a little rough. I blew an AC fuse and had some difficulty cramming all the wires in. In the end though, I did exactly as was described before on fitting wires and it ended up working.
Everything stock works perfectly. As far as the new unit, mostly everything works well. Start up is comparable to oem unit. Need to figure out how to swap out apps on the main screen, need to refine the system volume, get a noise filter for the aux connection, and CarPlay is a little glitchy when in the background. Otherwise, it looks practically OEM and is gorgeous.
Also, need to figure out how to route usb and aux directly to glove box. Currently, I have aux coming out from under the dash and into glove box, while usb is dangling from behind screen. I’m sure I’ll have to take apart the glove box for that.
I’ll upload some pictures later.
Old Aug 31, 2018 | 07:09 PM
  #52
Behold81's Avatar
2011 E350 CDI A207
Originally Posted by Dnasty
Not too bad. Thanks for all the follow up this might be a good stickie thread as I see a lot of people doing or wanting to do this mod.
i will try to do a full removal and setup and review bideo when I get mine. Should help a lot. I’ll create a how too topic. People can post in to it any extras.
Old Sep 1, 2018 | 04:55 AM
  #53
400ixl's Avatar
E250 AMG Sport Convertible
Originally Posted by Behold81
awesome. Do you have the proper tools? Or did you fashion something
For the armrest it was pretty much the star drive and trim remover tools. Plus a drill to make a hole to get the cables into the cubby hole. For the stereo part, it was the same plus the hook tool.
Small crew driver also for unclipping the wiring connectors.
Old Sep 1, 2018 | 06:47 AM
  #54
400ixl's Avatar
Some photos for people to see what it looks like fitted.
View of the screen mounted from the front of the car
View of the screen mounted from the rear of the car
View from the side (haven't fitted the caps to the dash mount yet)
View from the driver seat
Old Sep 2, 2018 | 07:49 PM
  #55
dmndE550cp's Avatar
2011 E550 Coupe
Figured I’d add some more pics to the mix...
Backup camera goes to widescreen when reversing during boot
Two USBs and aux come through hole drilled in bottom left corner of glove box
Still uses km in a couple places (even though I chose mph)
Apple CarPlay
Old Sep 2, 2018 | 08:14 PM
  #56
dmndE550cp's Avatar
2011 E550 Coupe
Also, I’m super happy with the unit in general. It’s works great. Navigation, music, BT, CarPlay, and stock system all work well!!
I only have a couple complaints in the end: 1) it’s a little glitchy sometimes 2) there is no way to change the apps available on the main screen.
Otherwise, if you’re willing to put in some effort and spend some time to install this.... then it’s well worth it.
I also suggest buying it from Chris at CKM, he was quick to respond to any issues I had.
Old Sep 4, 2018 | 03:38 AM
  #57
Behold81's Avatar
2011 E350 CDI A207
You can't change the apps but you can set them up with different default apps. so Navigation is Waze or TomTom ETC
Old Sep 4, 2018 | 03:49 AM
  #58
dmndE550cp's Avatar
2011 E550 Coupe
Navigation is the only one I know of that you can do that with.
Old Sep 4, 2018 | 06:08 AM
  #59
Behold81's Avatar
2011 E350 CDI A207
Mine Arrived today. Not sure It will get installed before the weekend. I will see. I have other car issues to sort!
Old Sep 4, 2018 | 06:21 AM
  #60
Behold81's Avatar
2011 E350 CDI A207
Originally Posted by 400ixl
Lets see if these upload OK.
Should be the ones you need to remove everything for fitting the unit and getting the phone wire into the aux port in the arm rest.
Do you have the screen removal on a W207. I thought it was slide but not sure.
Old Sep 4, 2018 | 10:03 AM
  #61
dmndE550cp's Avatar
2011 E550 Coupe
CKM Car Designs has a YouTube video that covers the screen and plastic frame removal.
Old Sep 5, 2018 | 05:20 PM
  #62
Dnasty's Avatar
2010 e550 coupe
Not to rain on the parade but has anyone noticed any difference in their collision prevention system notifications after installation of these? I recently got my car back from the dealership after a significantly high amount of false flags and seatbelt tightenings, I thought it may have been my aftermarket grill disrupting the radar but was told it was a tiny aftermarket blutooth/music adapter from amazon that I had plugged into the iphone jack in the glove box. This is a much more sophisticated product so i'm guessing this shouldn't be an issue but wanted to check before I do this on my 2010 e550.
Old Sep 6, 2018 | 02:58 AM
  #63
Behold81's Avatar
2011 E350 CDI A207
I don't have this on mine so will not know but as the unit sits outside the dash is should cause no more disruption than a mobile phone would.
I hope to fit mine this weekend so will see how it goes.
Old Sep 7, 2018 | 06:52 AM
  #64
400ixl's Avatar
I just slid the plastic trim remover at the top between it and the dash and prised it out. May have also used the hook tools to help as well.
Old Sep 7, 2018 | 06:59 AM
  #65
Behold81's Avatar
2011 E350 CDI A207
thanks I pried it out. now I know how. seen some articles with a different surround style that looks similar and is not the same pry out style
Centre vents look easy enough I have a DIY tool for them.
Should have it all in on saturday. looking forward to it.
Old Sep 7, 2018 | 07:17 AM
  #66
400ixl's Avatar
Centre vents can be a little tricky, you may have several attempts to unlock the catch and pulling out the vents, but shouldn't take too long to do.
Us a light to find where the holes are that you need to hook into and turn the hook to release.
Old Sep 9, 2018 | 04:21 AM
  #67
Behold81's Avatar
2011 E350 CDI A207
All fitted. But how can I get the rear speakers working??? Also does your sports button on the clock screen work.
Old Sep 9, 2018 | 04:38 AM
  #68
400ixl's Avatar
Rear speakers working for what? The OEM system (e.g. radio) , the HU syustem (e.g. music app)?
Mine uses all speakers for everything (for some reason Waze is only using one at the moment) but everything else is through all. Sport and clock (in cluster on mine) work fine.
If your clock is in the vents you may have a loose connection.
Old Sep 9, 2018 | 05:09 AM
  #69
Behold81's Avatar
2011 E350 CDI A207
the tablet is only using the front speakers. Need to test the command is still ok on the rears. I suspect they are.
The tablet on the the home screen has a section for sport,tunnel/recirculating mode and a few other bits. Not working.
Everything else is fine.
Old Jan 25, 2019 | 08:49 PM
  #70
SMG_CT's Avatar
2013 E350 4Matic Coupe
A good installation video for the 10.25 Android upgrade
This is for a W204 sedan which is very similar to the the C207/A207.
Old Jan 28, 2019 | 05:01 PM
  #71
drmohi's Avatar
E250 Coupe 2014 (C207 facelift)
hello, for those who installed the screen: how shiny is it? can it be seen easily when it's sunny? (the comand screen is incrusted in the dash so the light dos not hit it directly, but this screen is installed in front of the dash)
Old May 24, 2019 | 11:31 AM
  #72
drmohi's Avatar
Anybody??
Old May 24, 2019 | 12:48 PM
  #73
SMG_CT's Avatar
Look at post #54 in this thread
Lots of photos of the screen installed in a Cabriolet
Old May 24, 2019 | 01:21 PM
  #74
drmohi's Avatar
yes, but i couldn't find feedback about the visibility under direct sunlight
Old Jun 11, 2019 | 01:19 AM
  #75
mdzukunft's Avatar
2013 E350 Coupe
So I got my unit today. Came configured appropriately and everything (including CarPlay) works as it should. Routed the USB and AUX wires to the center console (what a ***** as my comand dial cable was clipped underneath the center console). Put each GSM antenna into the A-pillars and the GPS unit behind the rear view mirror.
I am having issues getting COMAND back into its spot. Tried for 3 hours and tore up my hands. Have been trying the advice of creating a hole underneath the unit by clearing other cables but still won't seat appropriately.
Also, I stupidly took out the screws from the CD unit and the locks are no longer in place. Is this maybe causing issues? As anyone screwed this up to? Any advice on fixing this issue?
