Figured out how to disable Eco start stop
Scanning the the various websites uncovered many people in a similar situation, where they just wanted to turn it off. But it seems the solution is not simple. Well I have found a solution which is easy to do and will cost you NOTHING!
i will explain what I did and for those of you with other models, you should be able to work it out.
I first got the fuse diagram for my car (found with the spare tyre in the boot) and looked up start stop. This had 3 fuses associated with it, however 2 of those fuses were used by other systems. One of the 3 fuses was ONLY used by start stop, number 91 in my case. I pulled out this fuse and BINGO, no more eco start stop! No check engine light either!
I taped this 10 amp fuse upside down in its normal slot so that I can reconnect the system if I ever need it.
Hope others find this useful.
i have a 1500km run in the car over the next 2 days. Will see if anything unexpected turns up.
cheers
cheers
Ran the scan tool over the OBD port and no system errors.
Nice
Judge, you need to remain unemotional and objective .
Judge said that I had been “randomly pulling fuses”. Where did that come from? That process was not used in this case. The process I used was logical where candidate fuses were first identified and then analysed. To me, using that phrase, followed up by the suggestion the approach was “foolhardy”, was a sign of an emotional response, aimed at discrediting this work.
Enough on that. So far the car is operating exactly as it was before, but without the ECO light and stop start function initiating on start up. I will be covering another 700km or so again today and will report back my findings, but this is behaving exactly as expected and looking pretty good right now.
cheers
regards
cheers
And just a heads up, some markets may have the fuel filter heater also on this circuit. This might be of interest to those that experience very very cold winters. Does not affect me as my minimums never get below -20 deg C.
Cheers
Facelift diesel S204 here .
Indeed fuse 91 is the Stop Start but it's also the filter heater that I assume is for warm coolant to heat the fuel filter ?
My local temps never get that low so no issue. Hope this helps.
cheers
