Putting thicker tires on the rears.
I assume you have an SE model then, as the Sport models have staggered setups as standard, at least here in Europe.
Also I have the sport with staggered width tires. The staggered setup I was talking about was putting larger diameter wheels on the back as well as wider. I’ve seen these on the amg s coupes.
The front and rear tires need to be close in overall diameter (height) to avoid problems with ABS/ESP. Generally up to a 3% difference is okay.
The formula for calculating tire height is:
(Width in mm x (2 x aspect ratio / 100)) / 25.4 + wheel diameter.
Example: 275/35R19
275 x .70 / 25.4 + 19 = 26.58" height
If height of front tire is at least (height of rear tire x .97), you should be good.
Example: 275/35R19
Thanks for the reply. Sorry if this is a noob question but why would it effect the sensors (or which sensors) if I go higher profile without narrowing the tire width?
now I'm also running a 2005 CLK500 Cabriolet.
Fronts are 245x30x20. I still might go to either 19 or 18's in the front when it comes around to tire time
Where are you located?
I've been running sumitomo tires on most everything I've own for the last 25 years or so. Except my Acura NSX'S 1999, 2001, 2005. I think I was in love with them.
I have a E400 that is staggered 255/35/R18 on the rear and 235/40/R18 on the front. I am also wondering if I can go 255/40/R18 on the rear. Is this possible ?
... But seriously I have the 550coupe and I think it could benefit from some bigger rear tires because of all the torque it sends back there. I also want a softer ride.
I've always wanted to try sumitomo tires, i've been using hankook on most of my benzes. Are sumitomos more of a softer tire? I want more traction because.. I like traction
... But seriously I have the 550coupe and I think it could benefit from some bigger rear tires because of all the torque it sends back there. I also want a softer ride.the ride is a bit stiffer but it handles much better now.
