AMG Rim compatibility c207 coupe
Old Jun 14, 2019 | 01:37 PM
Piotr Faron's Avatar
w207
HI.
Can you please confirm will these rims be ok?
these are the originals recommended by MB
front 8Jx18 ET45
rear 8.5Jx18 ET48
and I want to buy the ones from w212 sedan
front 8,5Jx18 ET48
rear 9Jx18 ET56
The Et in the rear is much different.I plan to add spacers if needed
Please advice can I mount these wheels (and with what tires?)
Old Jun 14, 2019 | 04:58 PM
Siegmann's Avatar
10-second E550
Originally Posted by Piotr Faron
HI.
front 8Jx18 ET45
rear 8.5Jx18 ET48
front 8,5Jx18 ET48
rear 9Jx18 ET56
Relative to body:
Fronts will come out by 3.4mm
Rears will go in by 1.7mm
Will fit fine as is, but spacers are a nice touch.
Suggest 245/40R18 front and 265(or 275)/35R18 rear.
Old Jun 14, 2019 | 05:32 PM
w207
Originally Posted by Siegmann
Relative to body:
Thanks for the anwser
But will these wheels not cause any bad driving at higher speeds?
Old Jun 14, 2019 | 05:34 PM
Siegmann's Avatar
10-second E550
If the wheels are straight and undamaged, and balanced once tires are mounted, they should be fine.
Old Jun 15, 2019 | 11:49 AM
Nyshadow's Avatar
E550
i have 18" 8.5 wide with a offset of 43 in the front and 18" 9.5 with a offset of 53 in the rear, and my car drives the same as with the factory rims.
Old Jun 28, 2019 | 01:11 PM
Warloiz's Avatar
E Coupe 2014
I am about to buy an MSW 25 set of wheels for my E Coupe 2015 220CDI but the manufacturer gives for the
Front 8 x 18 Offset 48 and for the
Rear 9 x 18 Offset 45.
Does anyone has experience with similar sizes to know if they will fit without any problems?
Old Jun 29, 2019 | 12:47 PM
Siegmann's Avatar
10-second E550
They will fit, but you can go with lower offset, especially in the front.
Old Jun 29, 2019 | 12:49 PM
Warloiz's Avatar
E Coupe 2014
Relative to body:
I try to avoid the spacers but my only concern is the fuel tank pipe behind the wheel which is only 2-3 cm away from the rear end of the wheel.
I tried the rims without the tyre to see the fitment.
