Rear left backrest not latched error... even though it is.
Old Jul 19, 2019 | 09:52 AM
Dnasty's Avatar
2010 e550 coupe
Just like the title says. I get this error even though the back seats are clearly latched and won't move. I've let em down and up numerous times to no avail. Has anyone encountered this issue? Wondering if it is a computer error or some aspect of the locking mechanism.
Old Jul 25, 2019 | 03:23 PM
konigstiger's Avatar
'71 Pinto
Without pulling codes, most likely one of the switches same part # for both sides 2048701251. Feeling ambitious, check ground points and pins 25/26 @ rear SAM connector.
Old Jul 25, 2019 | 03:29 PM
Dnasty's Avatar
2010 e550 coupe
Thanks, your the man with the answer as usual. It shows no codes for this issue. Is it possible to clear this error and just see if it comes back? I'll give the ground points a shot... where are they located for the left? Also going to check out the fuses.
Old Feb 5, 2020 | 09:35 AM
Dnasty's Avatar
2010 e550 coupe
I attempted changing the switch part to no avail last night. I get the code " B1DCD13 - Switch ' Left rear backrest release and locking' has a malfunction. There is an open circuit "
Was wondering what the easiest way to access the rear sam connector.
Old Feb 12, 2020 | 04:42 PM
Dnasty's Avatar
2010 e550 coupe
Anyone know the location of the grounding points? From the picture it looks like its near where the rear speakers in the trunk are but not sure.
Old Feb 12, 2020 | 04:53 PM
'71 Pinto
Left & right front seat crossmembers, see bottom of each photo.
Old Feb 12, 2020 | 05:47 PM
Dnasty's Avatar
2010 e550 coupe
Yea I’ve been trying to figure out location based on the picture but not sure. Is it near the rear sam or in the trunk near speakers like I mentioned? Also wondering if one of the wires in the bar that holds the latch could be punctured causing the short. Is there a way to inspect inside the bar?
Old Feb 13, 2020 | 08:40 AM
'71 Pinto
How about checking under the front seats.
Old Feb 13, 2020 | 01:00 PM
Dnasty's Avatar
2010 e550 coupe
I will check that out... but is this where the grounding point for a rear seat latch would be seems like an odd place?
Old Feb 13, 2020 | 01:06 PM
mrmotoguzzi00's Avatar
1) Never question konigstiger : )
2) Actually not an odd place, its a common ground and a lot of different circuits terminate there...
Mike
Old Feb 14, 2020 | 08:01 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Seriously, you can trust him; he pretty much always knows what he's talking about.
Old Jul 13, 2024 | 06:42 PM
Moto_MIA's Avatar
E350
Any luck getting this resolved? Just bought my son a c250 sport ed. and have the same error on the rear right seat.
Old Jul 13, 2024 | 09:37 PM
Dnasty's Avatar
2010 e550 coupe
I never resolved it but I’m fairly sure one of the stereo installers damaged a wire inside the bar that houses the latch because I moved my amp and noticed the holes they drilled were right next to it. I’ve just lived with the error as the seat clearly latches and unlatches mechanically without issue.
