Exhaust note
Old Feb 16, 2020 | 11:14 AM
rreilly's Avatar
2012 Mercedes E550 Cabriolet
Exhaust note
Is there an easy way to improve the exhaust note of a stock 2012 E550?
Old Feb 17, 2020 | 10:54 AM
vrmmm's Avatar
Yes, very easy. Go to your local exhaust shop and have them remove the large resonator and two bullet resonators, and install an x-pipe. Leave the stock mufflers and cats alone. Perfect rumble without being anywhere near loud.
Old Feb 17, 2020 | 11:03 AM
rreilly's Avatar
Thanks, vrmmm - I will look into that. I did not want to go for a full cat-back system and don't want it too loud. Sounds perfect.
Old Feb 17, 2020 | 11:05 AM
vrmmm's Avatar
You are in the exact same situation that I was in. This is the perfect solution. You will not regret it in the least!
Old Feb 17, 2020 | 02:29 PM
rreilly's Avatar
Ok, I will go talk to my muffler shop. Thanks again.
Old Apr 21, 2020 | 08:11 PM
chopsticksonly's Avatar
E550C
I went to my local exhaust shop today and asked about getting x pipe done.
They showed me under the car where the 2 bullets are and the big resonator. When you guys say "x pipe", do you mean x all the way from the bullet to back of big resonator? The shop says he thinks the bullets right in front are cats, but they're resonators right?
The exhaust shop guy suggested to either do an X where the bullets are and then straight pipe it down, OR straight pipe where the bullets and X on the resonator. Is this correct?
How much are you guys paying to get this done?
Old May 1, 2020 | 08:27 AM
Mozbenz's Avatar
2014 e550 coupe
I removed the small resonators, sounds great under acceleration with no drone. Still has the refined subtle v8 rumble under light driving and is definately audible when on the gas...always brings a smile.
Old May 1, 2020 | 08:32 AM
vrmmm's Avatar
The bullets are most definitely resonators. Straight pipe where they are, and x-pipe where the big resonator is. The sound is PERFECT! No drone, deep rumble while never being loud. It's how it should sound from the factory.
Old May 2, 2020 | 09:26 PM
E550C
Thanks for your replies. I was wondering - would it sound good if I removed the big resonator and just straight piped it to the mufflers? Also what's the deal with losing back pressure if I X pipe? People say X NA and straight pipe turbos is preferred. Is that true?
Old May 3, 2020 | 12:01 PM
sunny9781's Avatar
2010 e550
Hey any chance you have a sound clip? i am looking for a non-drone, enhanced v8 sound as well. thanks
Old May 3, 2020 | 01:22 PM
mikefalz's Avatar
2010 Mercedes Benz E550 Coupe
2010 E550 Coupe
I have a 2010 E550 (Naturally aspirated) Coupe and was wondering if your suggestion to remove the resonators and add an X pipe would have the same/similar sound effect without any negative performance or mechanical/electrical/sensor malfunction(s).
Old May 4, 2020 | 11:24 AM
mikefalz's Avatar
Old May 19, 2020 | 12:58 PM
quentinr1's Avatar
2007 clk 550(OE Tuned) 2013 E550 Coupe(Weistec Tuned)
I did just a muffler delete on my 13 coupe. Sounds great when on gas especially deceleration. I got it weistec tuned dont know if that makes a difference on exhaust note
Old May 19, 2020 | 01:20 PM
mrmotoguzzi00's Avatar
Resonator delete is a common mod to these cars... click here for pics of before and after...
https://mbworld.org/forums/e-class-c...550-coupe.html
Old May 20, 2020 | 11:39 AM
mikefalz's Avatar
I had read on one of these blogs that naturally aspirated engines (mine) do not necessarily have the same result as turbo engines (yours) and may even cause problems if handled the same way.
Old May 21, 2020 | 07:12 AM
Martyn.mogge's Avatar
E500 coupe 4.7TT
I swapped out the original rear mufflers for C63s AMG rear boxes and it gives just enough extra sound for me.
Got a local exhaust guy to cut and weld for me
Old May 21, 2020 | 08:19 AM
Aaahhh been waiting to see if somebody did this so they do fit.... can you give me some specifics ?
what year C63s ?
2 door or 4 door (unsure if it matters...)
Increased sound at normal throttle or just Wide Open ?
Assuming no drone...
Old May 21, 2020 | 09:44 AM
E500 coupe 4.7TT
The mufflers were from a C63s coupe not sure what year, got complete exhaust secondhand from eBay but only wanted rear mufflers.
They came with the exhaust valve actuators which because they are not connected are permanently open.
The original exhaust was cut and the AMG mufflers hanging bracket were tweaked to allow fitment along with a new bend to align old with new.
obviously not a straight swap. A good exhaust guy shouldn't have any problems.
I stupidly didn't take any pics when it was being done.
The sound is exactly what I wanted maybe 15% loader than stock with more of that glorious V8 rumble in cabin on part throttle but definitely not in the boy racer league. and no drone at all, which is also what I wanted to avoid.
I'm extremely happy with the outcome and will not be removing the resonators.
Only thing I would like to do is have the exhaust flap actuators operable with a remote for early morning start up.
for lots of relevant information search for thread - E550 convertible 2014 resonators delete +c63 performance exhaust
hope this all helps
Old May 24, 2020 | 11:27 PM
E550C
I ended getting my resonators deleted. The shop put an x pipe where the bullets were and straight piped the big resonator. I wonder if I should have just gone straight pipe for both.
I didn't take a before video, can someone confirm it is a little louder than stock?
Old May 26, 2020 | 01:55 PM
WIN ER's Avatar
2007 S65 AMG (W221)
Got me thinking. I have resonator delete (2010 C207 with NA m273 engine) but I do get some drone around 5K rpm after I installed the headers. The drone comes from the rear side. I don't think this can be fixed by a tune (already have my ECU tuned with stage-1) so I am scratching my head now. If anyone has an idea on how the drone can be distinguished I would appreciate an insight.
Thanks.
Old May 26, 2020 | 01:56 PM
WIN ER's Avatar
2007 S65 AMG (W221)
P.S. stock mufflers, shorty headers, straight pipes (resonator deleted).
Old May 26, 2020 | 04:48 PM
WIN ER's Avatar
2007 S65 AMG (W221)
Seems it might be those small bullet 'resonators' which go before mufflers, I always thought those are secondary cats. Need to take a look at the schematics to reconfirm.
Old May 26, 2020 | 05:56 PM
E550C
We have different engines but I haven't noticed any drone yet on my car. I did read that the NA engine will sound a lot different (read: LOUD) than the TT version and an x pipe might help with sound. People do call the bullet resonators "second cats" as well. When I looked in my bullets, its mostly straight through with a bend in the middle
Old May 30, 2020 | 12:36 PM
griza's Avatar
2006 CLS55 AMG Sold 2010 E550 Coupe totaled by mechanic, '13 SL550 I totaled it, 2017 SL63 current
2010 E550 coupe here, I chopped my mufflers off. Sounds awesome and cost $150.
Old May 30, 2020 | 12:51 PM
WIN ER's Avatar
2007 S65 AMG (W221)
Is it horribly loud or not that bad? Do you keep the big resonator?
