OBD Diagnostic socket fault
Old May 21, 2020 | 04:04 PM
snupys's Avatar
e250 cdi
My E250 cdi diagnostic socket doesn’t work, I have checked fuse box no 73 in boot and fuse doesn’t appear blown . Has this happened to anyone
E250 CDi
Old May 21, 2020 | 06:17 PM
snupys's Avatar
e250 cdi
Originally Posted by Plutoe
What do you mean dosent work?? More detail
The OBD socket ! Socket you connect the scanner to
Old Jun 17, 2020 | 01:04 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Jun 18, 2020 | 08:55 AM
WIN ER's Avatar
2007 S65 AMG (W221)
And how did you confirm on it's faulty status? Is it scanner that doesn't light up or something? Might be a bent or broken pin
Old Jun 20, 2020 | 06:19 AM
snupys's Avatar
e250 cdi
Hi I have checked the pins they seem fine ( looking back I visited Benz dealership to have a Bluetooth adapter connected Mercedes me which stop working last year I thought the problem was to do with the connected adapter now I know better . ) just hope it’s not the computer that damaged could be a costly repair 🤞
Old Jun 20, 2020 | 10:36 AM
snupys's Avatar
e250 cdi
I have checked fuse in boot 73 not blown can there be another fuse for the diagnostic socket.Obd 2 My fuse chart say fuse 73 in boot ?????🤷‍♀️
Old Jun 30, 2020 | 12:31 PM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
Mine says “link error”. Tried removing the diagnostic fuse in the trunk fuse box but no change.
dealer thinks it may be a communication error with the ECU and the ECU may need to be replaced. I’m taking it in next week
Old Jun 30, 2020 | 05:02 PM
snupys's Avatar
e250 cdi
. Oh even when u remove the Obd fuse the message still says link error on the scanner ??? What fuse number for the obd does it say on your vehicle chart ??
Old Jun 30, 2020 | 07:15 PM
yes, I pulled fuse number 73 which was the one that the little paper that came with the car. The scanner went blank I replaced the fuse but the scanner still read “link error”
Old Jul 4, 2020 | 05:28 AM
snupys's Avatar
e250 cdi
My issue is slightly different as the scanner remains blank with or without fuse , In your case you get a link error message
