Dynamic handling package
Regarding whether or not it changes the handling, I'm pretty sure I notice a difference (it's more rough in sport mode over bumps and stuff). Depending on the mileage of your car, it seems reasonable that the damping characteristics of the struts/shocks might be diminished. If there are no codes, my presumption would be that everything is functioning as intended (other than potential general wear which might not result in a code). If it's a big concern, just take it to a local specialist (and be prepared to pay a lot of money haha). In a worst case scenario where you might need new shocks/struts, make sure you get the Monroe version (about $330 vs $1200 for Mercedes) even though they're the same thing.
When I select the S vs E mode for the engine, it does make a difference in how the eng runs and trans shifts, but the suspension is the same.
I've never noticed any difference in steering between any of those settings. When I had a Rat chew my wiring and really screwed things up, the steering would switch, now and then, from normal to much harder to turn the wheel. Not sure what that's about but maybe there is least two different steering modes and it was confused and switching? I dunno, but it's never switched under normal conditions.
I do notice a difference, definitely tighter and stiffer when it’s in sport mode. My shocks and struts are new (less than 5k miles on them) so that could be why.
I don't understand how it's even possible, but clearly it is, and I don't know how to fix it. I posted a while back hoping someone would say it's xyz part that needs to be replaced, but nothing.
My suspension has never been touched so I suppose something is the cause, considering it didn't wheel hop before, but I have no clue what. It all looks good and tight, but who knows what happens at launch with all that torque. Maybe I should put a camera down there.
ibbij; is is possible that info is the bare min base, but the OP could have it as an option? I guess a VIN check is in order? https://www.lastvin.com/
@Chevota I’m sorry yours is having some suspension issues. If you were in Chicago I’d give you my guy’s number. He’d get under there and check everything. Have you done an inspection by a suspension shop?
If this has been the W212 E-Class Sedan it has option of air ride suspension as well as the S-Class coupe/cabriolet/sedan. Those all would be floaty vehicles. Anything with air ride will have floaty feel whether Mercedes or another manufacturer.
The firm suspension originating from the shocks/struts just seems to me to be firm from the onset with the way the chassis of the W207/W204 were made and never meant to be soft or float type instead more firm and grounded type. You’d had to have opted for a more luxury orientated Mercedes and not the sport orientated or base models.
