Banged up my fascia 2016 E400
Old Jul 22, 2024 | 08:46 AM
nickE400's Avatar
2016 E400
I did something boneheaded and wound up damaging my fascia. Before I take it to a body shop, I would like to try and push it out myself. Searching various sites including the forum it seems that applying heat and pressure from the backside could work. I am not looking for brand new aesthetics. It appears that I might be able to get to the backside with a heat gun, without removing the fascia.
The fascia is not displaced from any other side or angle.
There is a deep crease in it now. I will also need to replace the plastic chrome piece.
Any advice including how to remove the fascia, part numbers and others experience is greatly appreciated.
Thank you.
Old Jul 22, 2024 | 09:52 AM
The_Judge's Avatar
2018 E400 Coupe
Funny, I did the exact same thing to my 2018 E400 last month, misjudging the distance between my car and a concrete pillar in an underground parking structure (the detector missed it too, probably due to the steep angle between the car and the pillar). Felt like an idiot, feared that the whole piece would need to be replaced. But I took it to a small auto body shop near our home, and the owner told me that it could be rubbed out and repainted. When I went to pick it up a couple of days later, it looked like new, and I asked the owner what they had to do to fix it, fearing the worst. Turned our that they simply rubbed out the damage, which looked very similar to what's in the photo, and didn't have to repaint anything — it truly looked like nothing had happened to it. Cost me all of $80! So, I suggest that you check with a reliable shop before panicking.
Old Jul 23, 2024 | 12:57 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
No rubbing will fix that issue. It needs repaint. Buy the parts from china then take it to a autobody shop to repaint that section and call it a day. You will beed the chrome trim and bumper diffuser which can be cheaply acquired from fleebay.
Old Jul 23, 2024 | 06:40 AM
nickE400's Avatar
2016 E400
The chrome trim and bumper diffuser are easy enough. I plannned on replacing those. It's the front fascia I want to avoid having to remove and replace.
Old Jul 24, 2024 | 08:44 PM
Removal might not be needed but if you are replacing the inserts you will have to remove the bumper no matter what.
Old Jul 25, 2024 | 09:59 AM
wheatswake's Avatar
2017 S550 coupe, 2013 E550 coupe, 2008 Tahoe
pour almost boiling water over the area and push it out, worked for me on my Tahoe.
Old Jul 25, 2024 | 02:02 PM
nickE400's Avatar
2016 E400
That's a great suggestion I had not considered. The crease is deep, and I suspect that you poured the water on the outside of your Tahoes Fascia. However, I could do similar using a turkey baster from the inside and pushing it out. If it works I will certainly post it before I rent a heat gun!!!
Old Sep 19, 2024 | 06:43 AM
nickE400's Avatar
2016 E400
I used this YouTube video for guidance. The outcome is not perfect, but enough to satisfy what I wanted.
Thanks to all for their suggestions.
