Carplay upgrade
Old Oct 3, 2024 | 08:33 PM
  #51
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Originally Posted by nkx1
Isn't there a special adapter to connect to the factory GPS antenna? I'm almost certain there is from past reading, but I can't recall what it's called or where I read it.
None. I have the GPS splitter but the MB cable has a combination Sirius/GPS antenna so the regular splitter will not work, Using the MB GPS will be best but without doing modification on the actual cable it is a no-go. I won't risk damaging that cable.
Old Oct 12, 2024 | 05:29 PM
  #52
jtb33's Avatar
2007 GL 450 (former) and 2012 E550 Coupe
They sent me a new wiring harness and that fixed all my issues.
Couple leftover questions:
1) I know the 10.25" screen doesn't have a camera, so it can't detect ambient light. Is there an app that people are using to adjust brightness based on time of the day?
2) Where can I find new boot logo/animations that I can import?
Old Oct 19, 2024 | 01:48 AM
  #53
Does yours not automatically dim when your headlamp turns on?
Old Oct 19, 2024 | 03:12 AM
  #54
jtb33's Avatar
It doesn't seem to; no.
Does the dimming reflect in the Android settings? ie, if I have it set to 90% with the headlights off in the daytime, and I turn the headlights on, should I be able to see the android brightness settings show something lower than 90%?
Old Oct 23, 2024 | 12:44 AM
  #55
No. I have mine at 100% brightness then it dims automatically when the headlights turns on. It is a setting in the menu. One thing it does not do is turn dark mode automatically but I got used to it already as when it dims the screen it goes like 50% brightness.
Old Oct 23, 2024 | 12:48 AM
  #56
jtb33's Avatar
Interesting... do you know where that setting is for dimming when the headlights turn on?
Old Oct 25, 2024 | 05:14 PM
  #57
bjkaiserman's Avatar
2001 ML320; 2007 CLK350, 2011 E550 Coupe, 2020 E450 Coupe
Would any one of you like to comment or share what removing the radio unit involved. I need to replace my blown unit and wondered how difficult it is to remove? It's the same unit as yours in the photos.
Thanks!
Old Oct 25, 2024 | 06:26 PM
  #58
jtb33's Avatar
Thanks!
See post #28 above.
Old Nov 4, 2024 | 03:05 AM
  #59
here...
Old Nov 4, 2024 | 09:32 AM
  #60
jtb33's Avatar
Thank you! Mine did have this already set, but to be frank, I don't really notice any 'dimming' when the auto-headlights turn on. Even if it was, it's still super-bright at night. Might be more because it doesn't change to a night mode on things, so lots of white backgrounds on apps and maps.
Old Nov 7, 2024 | 11:08 PM
  #61
I'm toying on some settings on the unit and I did something that it made the night mode go automatic. I did a reset and it went back to normal so I am trying to figure it out again. When I manage to figure it out I'll let you know.
Old Nov 8, 2024 | 12:33 AM
  #62
jtb33's Avatar
That would be huge, if it were to do that automatically!
Old Jan 2, 2025 | 08:49 PM
  #63
There is a setting on the android system of "dimmer" screen. You need to manually select this. It is on the swipe down menu. Move the selection around the menu so that when you do the swipe down it shows on the first set of options. Also make sure to change to "dark mode" settings on the android system and have it turned on and off in a specify time.
Old Jan 2, 2025 | 10:15 PM
  #64
jtb33's Avatar
I can't find a setting that lets it turn on and off at a specific time...
Old Jan 3, 2025 | 04:31 PM
  #65
I'll take a few pics for you later....
Old Jan 4, 2025 | 01:57 AM
  #66
slickman's Avatar
E550 Cabriolet
I would like to see that too.
Old Jan 7, 2025 | 07:35 AM
  #67
carputech's Avatar
SPONSOR
Hello everyone, you can try our Mercedes Benz Coupe W207 2009-2016 NTG4.0/4.5/5.0 Linux Car Radio Multimedia Touch Screen, it may be helpful to you.
For Mercedes-Benz E Coupe W207 2009-2016 NTG4.0/ NTG4.5/ NTG5.0 System
Product Features:
1) Screen size: 10.25"/12.3inch
2) Resolution: 1920*720
3) Built-in Microphone
4) Built-in Bluetooth
5) Built-in WIFI
Functions:1) Support Wireless & Wired Apple CarPlay
2) Support Wireless & Wired Android auto
3) Support Airplay and Mirroring
4) Play video or music from USB
5) Compatible original cameras and aftermarket cameras
6) Original car wire plug and play,no cutting wire, no breaking wire,non-destructive
Compatible with all original OEM features. Contains steering wheel buttons, iDrive knobs, parking sensors, cameras, and more
Switch to CarPlay ororiginal system freely (press "Menu" Button on iDrive controller over 2 seconds to switch between two system easily)..
LINK:https://www.carputech.com/products/f...351d6181&_ss=r
Enjoy $30 OFF + Worldwide Free shipping ! (USE CODE: CARPLAY30)
Only for mbworld forum members!
Old Feb 25, 2025 | 05:18 PM
  #68
jtb33's Avatar
One more thing I've noticed since installing this... when my car is parked in the garage and turned off, my phone will randomly connect to the car's bluetooth when I am on the phone inside my house. It's as if the bluetooth in the new screen never turns off. Any fix for that?
Old Feb 26, 2025 | 11:32 AM
  #69
slickman's Avatar
E550 Cabriolet
Check your wiring as mine does not do that.
Old Feb 26, 2025 | 11:48 AM
  #70
jtb33's Avatar
How so, specifically? It's connected 100% per the instructions.
Old Feb 26, 2025 | 11:56 AM
  #71
slickman's Avatar
E550 Cabriolet
Something is keeping the unit powered on. After you turn off the car an you open the door, does the display shut down?
Old Feb 26, 2025 | 01:48 PM
  #72
jtb33's Avatar
The display unit will remain on when I shut off the engine. Once I open the door, the display unit turns off (including any music it might be playing).
Old Mar 1, 2025 | 04:00 AM
  #73
It should turn off maybe after a few minutes. On my vehicle it keeps the android on sleep mode for maybe 5-10 minutes so that when you turn off and on the vehicle it boots up quickly.
Old Mar 14, 2025 | 11:06 PM
  #74
AKSwift's Avatar
2012 E Cabrio, 2015 GL , 2017 B ED & 2024 GLS
I ended up buying a 12.3" head unit from Amazon (something Chinese). Awful instructions, but this was not my first rodeo.
It all works well, except the MB head unit keeps switching out of AUX back to Radio within a second or so of my playing anything from Android Auto. I found some suggestions to enable Audio Aux in the engineering menu, but that option is grayed out.
Has anyone come across this?
Old Mar 20, 2025 | 03:01 AM
  #75
go to the factory menu and click the aux on feature. See if that helps
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
