A/c pumps hot air intermittently
Old Jul 30, 2025 | 08:32 AM
Colin 59's Avatar
2013 A207
2013 E350 cab....Took it to a MBZ 3 rd party service shop and they could not find the issue. No codes and worked fine when hooked up to ac test. Was suggested it might be a pressure sw. or the compressor is on the way out. Spent a lot of money on diagnostics to get a non answer. Has anyone else experienced this problem?
thanks
Colin
Old Jul 30, 2025 | 10:01 AM
ibbij's Avatar
Bi-Turbo E550 Coupe (W207)
Google Gemini AI Overview
A car AC blowing hot air can stem from several issues, with a low refrigerant level being the most common. Other potential causes include a faulty compressor, problems with the condenser, or electrical issues.
Here's a more detailed breakdown:
1. Refrigerant Issues: Refrigerant Leak: Leaks are a frequent culprit, causing the system to lose refrigerant over time and struggle to cool the air effectively.
Low Refrigerant Levels: Even without a leak, refrigerant levels can naturally drop, impacting the AC's cooling performance.
2. Compressor Problems: Faulty Compressor: The compressor is vital for circulating refrigerant. If it malfunctions, the refrigerant can't move through the system, resulting in warm air.
3. Condenser Issues: Blocked Condenser: Debris, dirt, or leaves can accumulate on the condenser, hindering its ability to dissipate heat and leading to warm air.
4. Electrical Issues: Blown Fuse, Faulty Wiring, or Relays: Electrical components play a crucial role in the AC system. Problems with these can prevent the AC from functioning correctly.
5. Other Potential Issues:
Clogged Air Filter: While less common, a dirty air filter can restrict airflow, making it feel like the AC is blowing hot air.
Thermostat Settings: Ensure the thermostat is set to "cool" and "auto".
Broken Cooling Fans: Fans help cool the condenser and evaporator; if they're broken, it can affect cooling performance.
Clogged Expansion Valve: This valve regulates refrigerant flow, and a clog can disrupt the cooling process.
Old Jul 30, 2025 | 10:16 AM
ibbij's Avatar
Now that I gave you AI feedback, here's my personal feedback from having AC issues with my E550. It could be that the refrigerant is slowly leaking. I had to have my AC system "sealed" through one of the car ac sealant cans then recharged with refrigerant and has worked fine ever since. Also check that the compressor isnt freezing, I think mine might need replacing soon. I noticed so much water underneath my vehicle after I drive it so probably means the compressor is getting frozen however I am still getting AC so I'm just basically living on borrowed time.
Old Jul 31, 2025 | 08:38 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
You didn't give any indication as to how you define "intermittent" (e.g., every other day, twice a week, once a month, etc.). For several years now, my AC has intermittently blown hot air for about 10-15 seconds and then the output turns cold again. This only happens once every few months, so maybe once or twice each summer. I took it to the dealer the first time it happened (the car was then still under CPO warranty), and they found no codes and no other apparent cause.
Old Jul 31, 2025 | 09:23 AM
Colin 59's Avatar
2013 A207
sometimes when turning ac on blows hot for 5 min to 1 hour or longer , turning eng off, ac off , auto off selecting full hot then full cold sometimes resets system...happens about 20 % of the time...no leaks , no codes shown, no elect issues found nor clogged filters???
thanks
Colin
Old Jul 31, 2025 | 10:27 AM
RealDonn's Avatar
2011 E550 Cabriolet
I had a similar problem with my 2004 CLK500 convertible, which I later traded for an 2011 E550 cabriolet. Don't know if MB used a similar bit on the A207, but here's a link about that. It was maddening to figure out.
https://www.benzworld.org/threads/th.../#post-5249126
Old Sep 6, 2025 | 05:07 PM
Roth's Avatar
2010 E350 Coupe
I had this problem for the 1st 6 months or so when I 1st got my coupe. No faults, electrical issues, etc at the time. I bought a can of refrigerant (the A/C Pro) & it showed the system had no loss via the pressure tester built in to the cap of the refrigerant can.
I returned the can & did 2 things that worked.
1.) Short term fix was to wait until the car reached operating temp before switching the A/C on. It always blew cold this way.
2.) I started cleaning the system with Kool-It evaporator & system cleaner once a yr towards the end of summer. Was it actually that simple? Well, the notorious musty smell was gone (which the car had when I 1st bought it) & my A/C hasn't blown hot in over 4 yrs now. I also can put the A/C on right away & it still blows cold which it never did the 1st spring & summer I had the car.
Old Sep 9, 2025 | 11:07 AM
pl626's Avatar
2015 E400
Same frequency with my 2015 E400 Cab, one in a blue moon, so I've never pursued it. I've had a much more frequent similar issue on my '95 RRC, but I've never bothered with it, as it would require me to remove the center fascia which is extremely brittle plastic at this age...
Old Sep 10, 2025 | 09:44 AM
Colin 59's Avatar
2013 A207
Thanks everyone, summer is almost over in canada so not an issue now but manual calls for a coolant replace soon so will get them to check again at that service. Does not happen often but is inconvenient when it does happen and am going out for a nice drive on a sunny hot day when I leave the top up. Hope I can get to the bottom of it.
cheers , happy motoring
Colin
