Need Some Work Done
your dilemma is common.
When I've had this feeling..I usually start thinking about how expensive the replacement car will be...and usually the old car repair bill (or bills) is/are less than the sales tax/dealer fee's on a newer model. Then I start to think of how much a newer model would depreciate yearly, etc. Your e550 sound like a well maintained machine that is still a very attractive body style. Plus it has to put a smile on your face every time you crank up that monster motor! I would consider keeping it. You know its history.
But I'm usually wrong.
Motor on,
Mark
Motor on,
Mark
I'm probably keeping my '15 for as long as I'm alive...
The interesting thing about this car is the supposed $7-8K value of this car. As far as I can tell, there are only three or four 2012 cabs for sale in the entire country. The closet one to mine has 20K less miles than mine, but they are asking $16K. In the pics it does not look in any better condition than mine.
I read all about replacing the gaskets on the front engine covers but I did not do that I just tightened all the bolts on the covers I could get to and I must say I was very surprised how loose most of the bolts were. I gave the engine a good wash before the tightening job and so far leaks have not come back.
I don’t drive this car much. After the job I have put only about 400 miles on it so perhaps I need more time to know for sure.
For the value, what do you think you can buy for $3800 to replace your Benz? Not much I must say. You are not keeping it for selling or trading it in for value, are you?
If you like the car keep it and keep driving it. Take it to a garage and ask them just to tighten the front bolts on the engine and then wash it so you can see if it starts leaking again.
Tightening the engine front bolts has nothing to do with coolant lines. It is all aluminum parts that are bolted on the aluminum engine block.
if your only complaint is the oil and coolant leak the bolt tightening can very likely fix it and should cost way less than changing the gaskets.
my leaks stopped with bolt tightening and I don’t think my car is the only one where this helps.
