E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Easy Entry/Exit Question
Old Mar 4, 2020 | 12:21 PM
MikeyP's Avatar
2019 E 450 Coupe
Easy Entry/Exit Question: Whenever I get back into my car, the driver seat does not return to my setting. The seat readjusts - just not to my setting. Am I missing something?
Old Mar 5, 2020 | 10:11 AM
MikeO3's Avatar
2018 E400 Coupe C238
Sorry for what maybe a dumb question... Is the setting turned on for Easy-Entry?
Console:
Vehicle>Vehicle Settings Easy Entry/Exit
# Select Steering Wheel & Seat, Steering
Wheel Only or Off.
Old Mar 5, 2020 | 10:37 AM
MikeyP's Avatar
2019 E 450 Coupe
Console:
Wheel Only or Off.
Yes, setting is turned on for "Steering Wheel & Seat". When exiting, the steering wheel and seat both move as expected. When re-entering, the steering wheel and seat move back. However, while the steering moves back to my original position, the seat does not. The seat moves to some other position, requiring me to select my memory number on the door every time.
Old Mar 5, 2020 | 02:23 PM
johnnyblz20's Avatar
2020 E 450 coupe
I would love to know how to fix this as well. I just bought a 2020 E450 coupe and notice the same thing when I get it. It will move the wheel and the seat but doesn’t fully move it to my settings until I press the 1 each time.
Old Mar 5, 2020 | 06:26 PM
BenzC400's Avatar
AMG CLE 53
My seat didn’t move at all until I updated my COMAND firmware to version 04.80.00.20 from 03.76.00.10. It now moves to my driving position. However, the seat back does not. I have to press the memory button to move the seat back to my driving position.
When I shut off the car and open the door, the steering wheel moves up, the seat moves back, and the reclined seat back comes forward. When I start the car again, the steering wheel moves down into position, the seat comes forward and the seat reclines a bit, but not fully to my driving position.
Old Mar 6, 2020 | 08:20 PM
Tima I's Avatar
E450 Cabrio
I had same thing with mine. It simply doesn't make sense. I took it to dealership, they did an update or something, when I was picking it up they tried to explain me that it is supposed to be like that... I refused to take the car back, in a week they called me again and I picked it up completely fixed. Easy access and memory of the seat work fine and seat gets back to my driving position. Just take it to dealership and complain, they'll have to fix it.
p.s.
I also had the seat vent turning off after 5-10 sec working, the mirror light in the visor didn't work, seat belt did not retract back when unbuckled, sometimes side mirrors didn't fold when car was locked.
It's funny, they couldn't fix the seat belt, stating that mercedes is aware of that defect and currently doe not have a way to fix it. And again I refused to take the car like that. They simply changed the whole seat belt mechanism, now it retracts ok, but they said it might get loose in few months again. I will simply bring it back then. No way for me paying $80K for a car and put with any defects.
Old Mar 6, 2020 | 08:40 PM
2020 E 450 coupe
Did they tell you what exactly they fixed to get it working?
p.s.
Old Mar 6, 2020 | 08:47 PM
Tima I's Avatar
E450 Cabrio
No
Old Mar 6, 2020 | 09:01 PM
MikeyP's Avatar
2019 E 450 Coupe
This is reassuring. Now I know I’m not alone. Going to bring this up with the service dept., and we’ll see what happens. Sidebar: admire your owner audacity.
Old Mar 7, 2020 | 08:11 AM
sackboydad's Avatar
2019 E450 Cabriolet, 2020 GLS450
are you in the US? Exactly what model and year do you have? I ask because I took my 2019 E450 Cab 4Matic to the dealer and asked them to upgrade my COMAND to 4.80.00.2 mostly because I want the upgrade to the progressive display.
I was told they are only allowed to change software when there is a specific bulletin put out by MBUSA for a specific model to fix a specific issue. They said they checked and said my car had no such bulletin and therefore they could not and would not change any software.
now if you have the same model as I, I too have the issue where the seat won’t move on easy entry and exit. If it fixes it, I can go back and give them that issue.
Old Mar 7, 2020 | 08:42 AM
BenzC400's Avatar
AMG CLE 53
I have a 2019 AMG E53 Coupe in the US. I brought the car in for the Easy Exit not working issue and was told there was nothing they could do. A while later I noticed the COMAND system was slow and sometimes I would get a black screen, so they updated COMAND. Sometime after the update, I noticed that the Easy Exit system worked. I really don’t know if it was the COMAND update or just a coincidence.
Old Mar 7, 2020 | 08:43 AM
sackboydad's Avatar
ahh. Thanks. I’ll try that approach
Old Mar 7, 2020 | 09:11 AM
Tima I's Avatar
E450 Cabrio
Sorry for offtop.. What is a progressive display? Can you post a picture pls?
Old Mar 7, 2020 | 09:13 AM
Tima I's Avatar
E450 Cabrio
Old Mar 7, 2020 | 09:16 AM
mustangn8's Avatar
2019 A220
Same issue here
Same exact issue in my 2020 E450
Old Mar 7, 2020 | 09:25 AM
konigstiger's Avatar
'71 Pinto
Try setting the seat to move less than furthest rear position.
Old Mar 7, 2020 | 09:27 AM
sackboydad's Avatar
I think it's in this thread.... You have Classic, sport and Progressive instrument clusters. Someone pointed out that the newest version of COMAND has additions to the progressive display like being able to have two things in the center area, etc. I wanted to have those small items on the display
Old Mar 7, 2020 | 09:44 AM
Tima I's Avatar
E450 Cabrio
The dealership tried to get away with some kind like this explanation, like the seat is already too far and quote "seat is out of the range of the easy entry/exit system". The truth is following: my seat's driving position is very far and low. When I turn off the car and open the door, the easy entry/exit system LIFTS the back of my seat (as well as the steering wheel) and I get out more easily. When I get into the car and close the door, easy entry/exit system lowers the steering wheel AND lowers the back of the seat to my driving position.
Before, when I was getting into the car, closed door, the steering wheel went back to driving position and the seat DID NOT. And yes, the setting of easy entry/exit was set up for both: steering wheel and the seat. Obviously there was a software issue.
Just take it to dealership and show them and leave the car. Why digging into the problem that is already paid to be taken care of by manufacturer/seller? The seat HAS TO be brought back to the memory setting by easy entry/exit system. Period.
Old Mar 7, 2020 | 09:55 AM
Tima I's Avatar
E450 Cabrio
In Florida we have a Lemon Law for such cases.
Old Mar 7, 2020 | 10:00 AM
BenzC400's Avatar
AMG CLE 53
I really don’t have any complaints. I consider the COMAND and Easy Exit issues minor and they were ultimately resolved.
Tima I's Avatar
E450 Cabrio
Where in this thread? Can you post a link or something? I am obsessed with modifying the cluster and display, since it is digital I assume there should be a way to play with the way it looks like.
Old Mar 7, 2020 | 10:05 AM
'71 Pinto
So.... for those who may not have known a DIY reset to different position could resolve the problem without having to schedule a visit to the dealer this is why I posted manual page. Exact same problem dates back to the 211 this is why MB discontinued the feature for a while. Now then, dealer most likely reset the feature using Xentry (MB diagnostics) what does the narrative on your invoice document. If, in fact, they updated the software then so be it.
