E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
View Poll Results: Is anyone having problems with their garage door opener for their 2020 E450
Garage door opener doesn’t close
0
0%
Garage door opener opens but doesn’t close
0
0%
Garage door opener won’t open or close
0
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Garage Door Opener
Old Jun 12, 2020 | 11:40 AM
Susanb's Avatar
2020 E450 Cabriolet
Garage Door Opener
Hi, folks. I'm new to this forum. I have a 2020 E 450 Cabriolet and I have been experiencing problems with the garage door opener feature, I programmed the opener on the visor of my car according to the MB manual. When I push the button on the visor, it opens the garage. The problem I'm having is that when I pull into the garage and push the button to close it, the garage door does not close. If I leave the vehicle and push the button inside my garage, it closes so the problem does not appear to be with the garage opener but with the opener function in my car.
Has anyone else experienced this and have suggestions for fixing it?
Thanks!
Old Jun 15, 2020 | 10:20 PM
WWnyc's Avatar
E450 4Matic Cabrio
No issues with mine,
works perfectly
Old Jun 18, 2020 | 03:22 PM
HAWKiS63's Avatar
S63 AMG Cabrio
No problems here (open and close with same button).
Can it be your door has seperate (rolling?) codes for open and for close? Then you should program 2 buttons in the mirror: one for open, the other for closing the door.
Just try and program a second button to be sure.
Old Jun 28, 2020 | 09:55 PM
patrickG's Avatar
E450A
No problems with my opener
My 2019 E450 cabriolet has the opener on the rearview mirror. The units in my two car garage had a button to push. Both doors programmed without issue (except needing a step stool to get up to the learn button on the openers)
Old Aug 2, 2021 | 09:08 AM
SPOOKYB's Avatar
vehicle i drive is bmw
Sorry to bring this up, but I want to thank you for sharing your experience, I understand my problem because of you. It turns out my door had rolling codes, to open and close. I couldn't figure out what was wrong myself, but I read the tips on this forum and decided to give it a try. Called Emergency Garage Door Repair, and they programmed my door to open and close. Now I was relieved because I had to manually get out of the car and open the door every time.
Old Aug 2, 2021 | 04:42 PM
BenzC400's Avatar
AMG CLE 53
Originally Posted by SPOOKYB
Sorry to bring up this topic, but I want to say thank you for sharing your experience, I figured out my problem thanks to you
What was the issue?
Old Aug 18, 2021 | 11:14 AM
2150john's Avatar
E 450 4matic cab MY22
In my E350 cab, the garage button will not operate the garage door unless the motor is running. If you turn off the motor and then try to operate the door opener, it will not function. Don't know if this might be your problem. This is a
security feature so that if you leave your car outside of the garage no one can open the garage door without a key to the car.
Old Aug 18, 2021 | 01:03 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Originally Posted by 2150john
In my E450 cab, the garage button will not operate the garage door unless the motor is running. If you turn off the motor and then try to operate the door opener, it will not function. Don't know if this might be your problem. This is a
I hope OP is reading this. Car needs to be running.
Old Aug 18, 2021 | 02:38 PM
kasendorf's Avatar
2019 E450 Cab, 2021 E350 Sedan
On my 2019 E450 cab and in my 2021 E350 sedan the garage opener continues to work after turning off the engine as long as my door is still closed. Once I open the door the opener no longer works.
Old Aug 18, 2021 | 03:06 PM
or that.
Old Aug 18, 2021 | 03:37 PM
TimInCA's Avatar
'22 E450 Cab Order Canceled, Tesla Model S; Telluride
Could be the car not running and vehicle door open issue; however, another thing that can interfere with garage door openers are LED light bulbs. If the OP changed their opener to user an LED bulb, the door would open fine as the bulb is off, but once the door opens, the bulb can cause RF interference. Liftmaster/Chamberlain call this out as an issue. The OP garage door from button in garage, get in car, drive out ... does the door close with the buttons in the car?
Old May 30, 2022 | 03:43 AM
Zentro's Avatar
BMW X5
I have had problems opening and closing doors during power outages. There won't be a problem if a battery backup is installed. I recommend you don't skimp on it when you buy new garage doors at https://doorsdirect2u.co.uk/product-.../garage-doors/.
The electric drive levers are removed from the leaves to urgently unlock the swing doors. The work is not complicated. Four bolts are unscrewed, and as a result, the drive is easily disconnected not only from the leaves but also from the supporting pillars.
Old May 30, 2022 | 11:00 AM
The_Judge's Avatar
2018 E400 Coupe
Like Zentro, I recently had to replace my 25-year-old LiftMaster garage door opener, which simply died. On the advice of the technician a got a LiftMaster 8160WB. Very quiet, has battery backup (very important in earthquake country), works with the buttons on the rearview mirror, and also has a wi-fi connection to my cellphone. Works with an app on my iPhone that almost instantly tells me when the door had been opened and when it's been closed, shows the status of the garage door (open or closed and for how long), and allows me to open or close it with the press of a button on my phone. Nice features if you've ever had to go back to the garage or drive around the block to see if you actually remembered to close the damn door!
Old Dec 7, 2024 | 09:20 AM
yovenim's Avatar
just looking
Originally Posted by Susanb
Hi, folks. I'm new to this forum. I have a 2020 E 450 Cabriolet and I have been experiencing problems with the garage door opener feature, I programmed the opener on the visor of my car according to the MB manual plano garage door repair. When I push the button on the visor, it opens the garage. The problem I'm having is that when I pull into the garage and push the button to close it, the garage door does not close. If I leave the vehicle and push the button inside my garage, it closes so the problem does not appear to be with the garage opener but with the opener function in my car.
Thanks!
The issue is likely with the programming or signal between your car's opener and the garage door opener. Try clearing the memory in your car and reprogramming it from scratch. Make sure you're pressing the button long enough to send the signal to close the door. Also, check for any interference from nearby electronics. If the problem persists, contact Mercedes-Benz support for further assistance.
