E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
anyone convert to r134?
Old Jun 20, 2008 | 02:57 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
my ac compressor just crapped out after 29 years and 110k miles. my mb indep mech suggest converting the whole thing to r134... new compress new everything (whatever that maybe) for $900ish....
just wondering if anyone here has done it..... car run any different?
ill search the other forums but this one was my first stop...
thanks
Old Jun 20, 2008 | 08:55 PM
ohlord's Avatar
Compressor
http://www.autohausaz.com/search/pro...C%20Compressor
new drier,new lines ,the old ones will be contaminated flush everything that can not be removed,parts labor and r134a fill at $900 seems a bit high.If he installs an electric fan for the condenser it still seems high.Get some quotes from an a/c place.Very little change my 99 blows 38f air at idle on a hot day on low.
Old Jun 21, 2008 | 06:40 PM
POS's Avatar
POS
1966 250SE Cab, 1985 500SE Euro, 1985 190e 2.3-16 AMG, 1986 300E LeMons Car
Actually, I think $900 is about right for a new system. The w123s never cooled all that well with the R12 systems (at least not here in Texas), so going to a R134 system would make it even less cool.
You may do as you wish for Missouri, but I like all my old Benzes to have the R12 - it doesn't cost that much more than the R134 when you add up the total bill.
Old Jun 23, 2008 | 07:06 PM
cheapold280CE's Avatar
1978 280CE
why not try freeze 12, I heard it acts just like R12 so you don't have to change all the components just do some cleaning.
check out this page
http://www.dieselgiant.com/repairyourac.htm
You will never get 38 degrees with R134 unless you change your condensor to a more effective one.
Old Jun 24, 2008 | 03:48 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Freeze 12 is nothing more than 80% R-134a and 20% HCFC-142b. Its still not completely compatible with R-12's mineral oil.
Old Sep 14, 2008 | 06:13 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
lets see compressor, drier, expansion valve, flush the system the R134 Freon and labor for $900,00 sounds about right,
Old Sep 14, 2008 | 06:15 PM
tanktube67's Avatar
If I were you, I would replaced the a/c hoses 2
Old Nov 7, 2008 | 08:01 PM
Benzguy604's Avatar
126,123
I have done the conversion a couple of years ago.And all I replaced was the high and low pressure valves on each hose.I never had a problem with the A/C since this retro fit,my pressure is stable and of course no leaks! and plenty of COLD air.
This was done on my 1983 126.
Regards
Big Dan
Vancouver Canada Eh!
Old Nov 26, 2008 | 12:28 PM
tanktube67's Avatar
Regards
Big Dan
I have done the same thing on some of my cars
Old Jun 3, 2009 | 12:55 PM
dogbite5150's Avatar
w123
I've taken courses in auto HVAC repair.
I've added r134 to an empty r-12 system before and it worked. However....
If you have access to equipment you could pull a vacuum on the system and try to pull the ester oil out of the system. That will also pull the moisture out of the system. 20 minutes minimum.
Flushing could also be done, but that is probably unnessecary.
You can buy 134a with pag oil in it (usually in those conversion kits) or just add pag oil to the system prior to charging. You'll never get every ounce of ester oil out of it. You can keep track of the oil that comes out and add roughly the same amount of pag.
As far as "converting" all you really do is use the fittings so you can add 134a.
One thing to consider. Hoses designed for r-12 will ordinarily leak 134 because the 134 molecules are smaller, but because the system had r-12 in it. The hoses are coated with oil and r-12 molecules, thus preventing leakage. If you flush....well you might get leakage.
Old Jun 3, 2009 | 02:39 PM
w123
Of course if there are mechanical issues in the system that is the expensive part
