E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Follow up #2
Old Dec 17, 2008 | 02:06 PM
Benzguy604's Avatar
126,123
Follow up #2
Its done!
I was not able to get all of the pictures that I wanted,being alone to do this, and its pretty cold up here and snowing too.But I did install an insert (HeliCoil) on the oil filter housing.Not much room to drill from above so I had to go under the car and drill the hole to remove the old threading.I was lucky enough that I didn't have to buy a new HeliCoil kit since it was the same size and diameter as the one I did on my transmission oil pan last summer http://benzguy.piczo.com/howtodothre...kvar=000044.In any case its a done deal,of course RED locktite was applied.Took less then an hour to complete the job but I had to wait about two hours before starting the engine,only to let the locktite set.
Cheers!
http://benzguy.piczo.com/wouldyoulik...linkvar=000044
Attached Thumbnails Follow up #2-img_1301.jpg   Follow up #2-img_1302.jpg   Follow up #2-img_1303.jpg   Follow up #2-img_1305.jpg   Follow up #2-img_1310.jpg
Old Dec 18, 2008 | 08:08 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
I think your engine bay has dandruff.
Old Dec 18, 2008 | 10:33 AM
Benzguy604's Avatar
126,123
Ya you got that right!
Still snowing today!
Cheers
Old Dec 28, 2008 | 06:58 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
You forgot to wipe out the luck tight excess around the bolt, just my two cents.
Very good job aver all.
