New to W123, a question?
If the info is not there start a thread with the same question.
Yes, that little Valve Cover Valves only control the EGR on your year and model.
Good to hear that all those valves do is control the EGR. I'm definitly going to remove them to clean up the clutter and reduce linkage drag a little. Thanks.
They get them on eBay for around $9-13 dollars.
You can adjust the pressure that the valve opens at.
The trick is that in order to adjust the pressure you need to have at least a temp gauge hooked up.
Before you buy any valve you might hook up your gauge and clamp off the Hose going to the waste gate and go for a drive and see what type of Boost your Turbo will put out.
Drive it just long enough to find out the info.
I drained the gearbox oil. Now I am looking to clean the gearbox filter. Where is the filter. I did not see it in the sump. Is it that round nut next to the plastic vacuum adjuster? The oil that came out was dirty.
Where is the filter. I hope it works after I clean the filter and replace the oil with ATF. Do I need to use a special oil?
