How to install clear/smoked corner lights?
Behind each corner light...there will be a clip that holds it in place very much the same thing if you look at the smoked ones. Push that clip down and you should be able to remove it. It might be a little rough since OEM lights fit nice and tight but it should be okay.
When installed the new ones, hold the clip down and make sure when you push it in..the clip snaps onto the body or else it'll pop right out when you drive. I hope this was enough information, I don't see how else to explain it. lol
Freddie, what pictures are you talking about?
