e320 cant get eng up to 80 degrees
the air coming out of heat vents corresponds to engine temp. meaning I only get mildly warm air from the heater when the engine temp is 60 or under. when the engine temp rises to 80 I get truly hot air from the heater.
most people on this forum are struggling to keep their engines cooler. search on the forum for "engine too cold" did not bring up any matches to my problem.
1995 e320
161k
m104 6cyl
when i pulled the old one out, it came oout in 3 pcs. lucky none of them were small enough to fall in.
whole process took 20 minutes.
engine warms right up to 87 degrees and stays there.
what a pleasure!
when I moved one of the vacuum lines out of the way, it was so brittle it just broke in my hands. I can imagine how much other stuff under the hood is brittle. I have nightmares about the harness being a time bomb getting ready to go off.
Check the engine wiring harness. Remove the wrap and check the condition of the insulation. If it's brittle - replace the whole engine wiring harness as preventive maintenance. Don't wait for problems to happen.
