Accumulator: Can it be tested
Can the accumulators be tested to see if they are working? They appear to be the orginals on 1992 with 133K miles.
Thanks.
The hollow hex head bolt that goes thru the banjo fitting is a 10mm hex head bolt. torque to 30Nm
The other fitting on the accumulator is 11mm. torque to 14Nm
The three bolts that hold each accumulator are 10mm. torque to 22Nm
All fasteners came off easily except 10mm hex head. To avoid stripping the head I use a 3/8" impact with suitable extension. The other one was so tight 3/8" drive impact would do nothing. I used the ½" drive impact and it came right off.
They are located under the car; once the three 10mm bolts are removed you put them up from inside the car. You remove an access panel to get them which is in front of the optional rear seat.
I have a mid rise sicissors lift so it was easy.
also, i stopped by an independent last week and he was showing me another wagon that need the "hydrolics" because it's leaking and the entire job he's quoting $1500.
i'd like to keep my car a bit longer for $500...but not really that excited about paying $1500 for it because it's nice to do, but not really required.
any thots?
If it's not the hydraulic pump
and
it's not the rear axle level controller
and
the rear struts aren't leaking
the accumulators are bad.
This is in the W210 maintenance DVD--W124 is essentially the same
