Unbolting the fan clutch (M103)
The hex bolt that holds the fan clutch on isn't reverse-threaded,
is it? I ask because the service CD shows using a torque wrench
to turn the bolt CCW, and I don't think a torque wrench should ever
be used to loosen a bolt, so that would imply to loosen I turn it CW...
MY bolt is seriously stuck, and before I really get to yanking on the
thing I want to be sure I'm yanking in the right direction...
Thanks,
-- John
John Sandhoff sandhoff@csus.edu Sacramento, CA
good luck,
jayare
Thanks,
-- John
Indeed, standard (lefty loosey) threads. I bent a piece of metal rod to
catch the locking hole and with an oversized breaker bar it came out.
In fact, I've now got everything apart (I'm replacing that pesky shorty
coolant hose - what a task! But there's lots of other maintenance, like
coolant change and a new poly belt, that's overdue anyway). Time to
order parts and then see if I remember how everything went together...
Thanks!
My 92 300 TE is making a fair amount of noise at the front and it doesn't seem to be either the water pump or the air pump.
Is there a way to test or diagnosis the fan clutch bearing when you think that might be the problem?
room to work. Perhaps if the rad is still in the extra room gained would help?
The dist is three hex head bolts and if you're high mileage you should check
the cap and rotor anyway (mine is in bad shape and will get replaced).
You may be able to use a mechanic's stethoscope (el cheapo ones available
from - gasp - Harbor Freight) and listen to the housing. If you hear grinding
or rumbling, that's your culprit. Be careful probing around a running engine!
You can use a piece of rubber hose, too, to help isolate the general location
of the noise. You want to be sure you're poking in the right place. Just hold
one end to your ear and poke around with the other end.
If the poly belt was off you could check for any side play. If it wiggles,
that's not good.
It's hard to describe the noise kind of a whirling but loud not like the other acessories.
I just got this car a few weeks ago and I'm going over it. I've replaced the distributor and rotor along with lots of other stuff too.
unhappy, but I'm much more inclined to say that this bearing itself is bad.
Is the clutch (the aluminum unit the fan bolts to) oily? Perhaps if
it lost its fluid it could start making noise, but... I think it's the main
support bearing.
Is that pulley called the Acc. Belt Idler Pulley?
I don't think there is anything wrong with me fan clutch.
Thanks,
-- John
i have a 1993 220 ce 4 cylinders
i observed my fan clutch behavior and i saw that it's different from the one on a bmw 318 1992, the one of the BMW disconnects the fan when the car is cold & on high RPM u can feel it easely coz the fan doesn't throw too much air u can even stop it!!!
so i thought that the one on my benz was not ok and it was connecting the fan in a contenious manner, so i bought a new one and i changed it but unfortunatly i didn't feel the difference it's still not like the bmw's
is it normal to act like this!
coz i live in the mountains and i get down to the city every day so on my way down the temp gauge shows 40 all the way down, seems like the car doesn't warm up until i hit the traffic jam, i checked the water temp valve it shows 87 that means that it doesn't open and circulate water until it reaches 87 degrees
so why the car doesn't warm up?
it's not very good coz the car consums much gaz on low temp, it should be up and stable around 80 i guess,...
thanks for any help
coz i want to know if it's what happens with all other cars or is their something wrong with mine...
Here is a picture with the fan clutch and the pulley behind it off. You can obviously see the slot where the smaller end of the breaker bar mentioned above will fit to lock the hub in place so you can remove the center bolt. The hub has six holes: four that are threaded for the bolts for the pulley, and two unthreaded for the breaker bar to fit in. Here is a view from the top.
Again, I post these pictures because it is not really obvious where to stick the breaker bar, especially considering the 17 years of road grime caking the entire area, and with the pulley and the fan clutch in the way. Hopefully these will help some other frustrated soul.
