Anyone know how to reset the odometer?
If it can't be done DIY, who can do it?
when you plug it in, it will go to the milage that your car has. its automatic.
mark
If it is mechanical, it takes some DIY capabilities and 2 hours time, to reset it where ever you want it to be.
Pull out the instrument cluster. Take out the odometer part. Pull the axle of the digit wheels, (you may have to clean one end of the axle to be able to pull it) set the milage to the value you want it to be, put back the axle, and put everything back in place. Mechanically you need to be very carefull all the wheels and things fit correctly together.
I have bad luck in that when I remove something to repair something else is broken. In this case my oil pressure gauge gave up. It's okay with my spare panel but now my brake light is in the light out indicator (different year)...
Thanks!
Thanks!
The pressure gauge may have a broken sensor, (a known problem). The position of indicator lights can be corrected in two ways. 1- just position the rigth indicator light in the right chamber, 2- swap the transparent foil (where the symbols are printed on) from the old to new cluster.
But what puzzles me more is the fact that the odometers/speedometers come in many different gear ratios. (4-cyl. 6-cyl. 8-cyl, 4-matic, different sub suppliers, different years, you name it....) So the replacement may not fit the from the internal (cluster)-ratio. The result will be a inaccurate reading for the speedo and odo. You can find a number on clock, if is the same, ok. Even if it is not the same it still may fit, but very hard to tell.
What's wrong with your old cluster? Maybe you can just swap the defective parts, as long as you don't change any of the drive parts.
