She stopped running... help me :(
Fuel filter? i just changed it during the whole tune up process... bad fuel maybe???
Matt
Did you check for spark?
Did you check for fuel?
Once you answer those we can better help you.
If it has no spark, you need to check the condition of the cap/ wires/ rotors/ coil/ etc.
If all those are good, then you may need the EZL module, which is sitting on the fender behind the abs pump. if that goes bad, the car will turn over, but wont fire.
If it simply is not getting fuel, it could be that the fuel pumps arent working.
Matt
) but stll did not fix. talked to mb dealer and he told me to try the over voltage something or other. he replaced it for $130 and it has run like a top since. in hind sight i should have done this my self as the part was only about $70, and just sits behind the battery(you have to remove your battery to get to it) probally about 30 min to replace if your are taking your sweet time.
