Possible Modifications to 1991 300ce?
Rating: Thread Rating: 9 votes, 5.00 average.
Old Jun 6, 2010 | 10:56 AM
  #426
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
Using Ps2cho's source:
$166. rear
$236. front.
$140 (my as new B&G springs, maybe less$, 40% off of your best real deal on them)
$542 no shipping costs if you stop by for my springs.
I just cancelled my 2 month backordered Koni's from http://www.koni-na.com/
and am using ps2cho's suggested source.
Old Jun 6, 2010 | 12:39 PM
  #427
Saijin_Naib's Avatar
1990 300ce 24v I6
Wish I could use his source, as I stated in the US Bilsten catalog a Sport strut/shock application does NOT exist for my car in my year. At all. End of story. Comforts or HD is all.
I need to use the Euro cataloge and I'm blocked from doing so by having a US IP address.
I've called the supposedly helpful Bilstein reps and they said sorry, nothing for your car. It is for this reason I've turned to the Konis for now. Unless someone can find me a Bilstein application guide for the Euro market that I can use. Even then, how am I going to get them here?
Old Jun 6, 2010 | 07:26 PM
  #428
AMGDave's Avatar
300D, 500E, E420
Bah, all standard (non-SLS) W124 shocks & struts are interchangeable. They just don't offer anything coupe-specific. The sedan stuff will bolt up. KONI only has one set each (red & yellow), they just say it will fit everything including the coupe, while Bilstein does not. The valving may be slightly different between sedan, wagon, coupe, and cabrio from the factory but I bet we're talking pretty minor amounts here.
Funny thing is, I looked up the 124.051 coupe in the EPC and the Sportline coupe dampers are the same as on the Sportline sedan! So, the Bilstein Sports (or KONI's) should work fine, regardless of what their catalog interchange says.
Old Jun 6, 2010 | 08:47 PM
  #429
1990 300ce 24v I6
Ahh, okay. Good to know. Should I then use a m104 equipped (94/95 e320 coupe) as the reference for my Bilstein Sport shocks/struts then? I assume the engine weight etc will be more comprable than say the m103 sedan would be. Or does that not even matter? The V8 ones are different, correct? All the I6 should be the same?
Old Jun 6, 2010 | 08:55 PM
  #430
1990 300ce 24v I6
Question:
I just clocked my 0-60 time with my father and I in the car and from a dead stop it took about 13s to reach 60 foot to the floor.
What am I looking at here? Plugs? Wires? Fuel delivery system? Exhaust? Car seems to run smoothly if not limp. Trans doesn't slip or take excessive time to shift.
Old Jun 6, 2010 | 10:23 PM
  #431
ps2cho's Avatar
E
13sec is definitely slow!! Heck even my 2.6L I thought was slow checking in at ~9sec. Were you feathering the throttle until peak torque or just flooring it from 0? It does make a 1-1.5sec difference to hit the right point. Takes some testing and practice. As my 2.6L has less torque than the 3.0, I really kick down at ~3k, rest is a heavy feathering until then. I used to be able to get the tires to screech from 2-3! No longer with the 18's...
Seeing as you are on a budget here's what you can do for free:
1) Check the resistance of all wires and see if they are within spec (resistance is written on wires)
2) Pull plugs and check condition and make sure they are gapped correctly. Got non-resistor right?
3) Check for any codes
The rest is m104 specific, so I won't give advice that I don't know.
And yes those shocks will fit fine, don't worry You may want to hold out on the springs and just do the shocks first because it will give you a ~1/2" drop from the sports alone. My ride height was jacked up, so you using the same setup as I have would be probably another 1" lower than me. FYI. I would do shocks first, then go from there. It may be wise to go with sportline springs over eibachs/h&r.
Old Jun 6, 2010 | 11:38 PM
  #432
AMGDave's Avatar
300D, 500E, E420
Yep, I would see if you can find what you want for the late E320 coupe. If they don't list anything for that either, then look for the E320 sedan items. The V8 cars are heavier and have slightly different components, particularly the front springs. The same KONIs are used on all of the above, though.
I just clocked my 0-60 time with my father and I in the car and from a dead stop it took about 13s to reach 60 foot to the floor. What am I looking at here?
Hard to say. Is it upshifting at redline each shift, and starting out in first gear? I assume you are running premium gas (91-93 octane)? I'd start by at least pulling the plugs & cap/rotor for inspection, checking DTC's (codes), and perhaps a compression test for grins. Factory spec 0-60 on your car is approx 8.0 seconds, btw. Oh yeah - verify your speedo via GPS (at 60mph) and make sure you are using a stopwatch to clock it. If you are significantly above sea level, that will also slow things down a bit (but not THAT much).
Old Jun 7, 2010 | 02:13 AM
  #433
1990 300ce 24v I6
If I search the 94/95 model years on the Bilstein US site I do not get any of the I6 w124s, only the e420.
1993 is the last year that yields an I6 (granted only a 300e) but I guess as you guys have pointed out, this is close enough.
So then, the Sport shock listed for the 1993 300e Front application is this:
(F4-V36-0365-H0)
For the Rear Sport application, there are two items:
(F4-B36-1470-H1)
(F4-B36-1470-H0)
Both of these rear shocks have the same price, same description, and same length cited (36mm). Should I just match the H0 of the Front to the H0 of the rear or is something else going on here?
I feel like I'm the only person who ever runs into these kinds of difficulties :P
Old Jun 7, 2010 | 02:26 AM
  #434
1990 300ce 24v I6
Thanks Dave and Ps2cho. Good to see that both of you are along the same lines as to what might be wrong here, so I guess I'll focus on what you've both suggested.
Yes, pegged to the floor, starting in 1st, going to redline. It was running high 11s during the winter but I assumed that was due to the snow tires and the winter mix fuel, but things are the same if not worse now and I know we've switched over to summer mix here in NJ. I only run 93octane in it now and had just run some Prestone Fuel System Cleaner + Prestone Octane Boost before the SCCA meet as my fuel gauge was doing the tango and that seems to cure it for a few months at a time. I know that float eventually needs replacing but for now..
Pulling the plugs.. I asked before but I'll ask again. Simply grab the plug jacket and pull? I was using a fair amount of force and they were not inclined to exit the head. Do I really need to muscle it or what? I don't want to break **** :\
Code reader requires the Radioshack hack, correct? I should be able to breadboard that fairly easily as that is about as far as my circuitry skills go.
Compression/vac test is something that can be performed at any shop or is that a dealership service? The dealer by me is more of a theif than any other dealer I've ever encountered and I'd rather not do business with them.
Plugs are non-resistor Bosch if I recall correctly. I'm probably going NGK Coppers. Should I do new wires for the hell of it or not? Physically, they look fine.
Ps2cho, what wires am I resistance testing? The engine harness or the plug wires?
And yeah, thanks a ton again guys. Hopefully I can get this sorted in time for the next meet. If I was able to drift the crap out of the car with it performing at 60% then it should be a total blast at 100% :P
Old Jun 7, 2010 | 03:08 AM
  #435
1990 300ce 24v I6
Anyone with a m104 w124 in the Cali area feel like being adventuresome and having Magnaflow prototype a custom exhaust kit for us?
Benefits to the donor car being you get the final kit free of charge Benefits to us include we get a kit that is dyno tested and guaranteed to fit.
Plus, I'd love you forever :P
http://www.magnaflow.com/10projectvehicle/prototype.asp
Old Jun 7, 2010 | 07:46 AM
  #436
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Brett
Did you modify your intake system.....?
For some reason I remember you posting about some "device" you added.
Buy yourself a pair of spark plug boot remover pliers...
This way no chance of damaging the wire.
What you need to do is what I recommend to everyone but no one seems to listen.
Tune the engine and make all adjustments to factory spec.
This gives a baseline to modify from.
Do a compression test and leak down test.
Be more concerned with cylinder variance then the PSI reading.
The age of your vehicle would typically mean that your vacuum lines are brittle and subject to leaks.
You have an early M104-24V with the CIS-E?
If so check the condition of the boot between the air valve assembly and throttle valve.
These also tend to crack with age.
Have you checked the condition of your catalytic converter?
Blockage will seriously impede performance.
If you are truly turning 0-60 times in the 11-13 second range, then I would stop thinking about anything other then the engine.
For the time being forget about suspension, wheels, tires, anything other then the stock drivetrain...
My M103-12V when stock had no problem running sub eight sixty times...
Perhaps because from new it was always maintained to factory spec?
Ed A.
Old Jun 7, 2010 | 10:33 AM
  #437
ps2cho's Avatar
E
Yes the ignition wires. As Ed suggested buying a pair of spark plug pullers is a good investment, but you can remove them safely without. Give them a gentle twist each way while pulling. Don't 'tug' them with brute force as you'll simply stress the rubber.
Making sure all ignition elements are fresh is an easy one. Most any euro shop can do a compression and leakdown test for you. It would be a wise investment. Don't pay them more than $50 to do it or you are getting ripped off so call around ahead of time for price quotes.
Ed I have a question for you -- My 2.6 when I did a test got ~180psi across all cylinders, but the leakdown results indicated a loss of ~25-30%. Seeing as she drives perfectly fine could the gauge be a little off? There was noticeable air loss though I could hear. I didn't pinpoint though at the time. This car has less than stellar history, so it is no surprise. Longevity-wise as long as I keep my oil changes frequent do you think the motor will still hold on another 100k or so?
Old Jun 7, 2010 | 11:17 AM
  #438
RBYCC's Avatar
180PSI per cylinder is great..
I'd do the leakdown test again...under 30% still isn't problematic...10% is fantastic and 20% is still a strong motor !!!
Old Jun 7, 2010 | 12:53 PM
  #439
1990 300ce 24v I6
Originally Posted by RBYCC
Brett
No device, just K&N filter and HVAC R-Value 4 heatwrapping around the intake boot and the airbox to try and reflect back some engine bay heat from getting into the air intake.
Mercedes one or just any one?
Well, its not like I didn't want to listen I just never really noticed how the car was actually performing. It is still smooth and idles smooth and everything so it never felt wrong.
Apparently my dad has all the tools for the compression/leak tests so I guess I'll have him do it the next time I'm home.
Vac lines are pretty much a pull every one and replace every one issue, correct?
Do you have a photo of this or the name of this part so I can look it up in the EPC?
Should be fine. Full exhaust replacement 2 summers ago when my mufflers rotted out.
Ed A.
Probably. I've not maintained the car well but I also don't know how to much of this by myself.
Old Jun 7, 2010 | 12:57 PM
  #440
ps2cho's Avatar
E
Just be careful...tracking the car like that without any sort of maintenance in mind will not end well.
Old Jun 7, 2010 | 01:07 PM
  #441
1990 300ce 24v I6
I try and keep up on fluid maintenance, aka, all I know how to do or have done for me :\
Oil is kept after, as is trans fluid, radiator, etc. I watch engine temps closely and keep mindful for any change in behavior of the car as I'm tracking it.
As I've said, the car has pretty much always been this way I've just never bothered to clock it and get a number.
Ps2cho, you interested in getting a Magnaflow prototyped for the m103? I think you'd make a lot of people happy
Old Jun 7, 2010 | 03:36 PM
  #442
ps2cho's Avatar
E
Sorry, say again?
I have a hollowed out the precats and had the exhaust shop weld in a high flow magnaflow cat on my wagon, but that's it...Nothing special.
Old Jun 7, 2010 | 04:33 PM
  #443
1990 300ce 24v I6
Sorry, say again?
Info Concerning Magnaflow Prototyping Program
Basically, if you apply and Magnaflow approves your car, they will build and prototype a dyno tested 100% guaranteed custom exhaust for that vehicle application that will be added to their catalog.
You get the prototyped exhaust for free. Other m103 w124 owners get a dyno proven full exhaust they can purchase and bolt up.
I'm considering applying for my m104 but I have to get it running factory spec first and then figure out how I'd drive it cross-country and what'd I do for about 10 days :\
Old Jun 7, 2010 | 07:02 PM
  #444
ps2cho's Avatar
E
Oh wow RSM is right down the road from me...literally!
Doubt they would accept an older non-performance MB, but I registered for the heck of it Would be awesome if they picked me!!
Old Jun 7, 2010 | 07:13 PM
  #445
1990 300ce 24v I6
Sweet, so that makes a m103 Sedan (and possibly m103 Wagon) available to them as well as a m104 Coupe. We just have to see if anyone else is game to apply and get the whole w124 range covered.
I think that we've got a great group of knowledgeable people as well as a growing group of younger people who are into the mod scene. The w124 is finally affordable for people in our age bracket and I think its time as a tunable car might just come forth now.
Maybe if we throw some weight around we can get something moving
I've emailed Renntech about their w124 performance mods and such and I'll see what they have to say in return. They might just have blacklisted me as a crazy person but I hope not.
Old Jun 8, 2010 | 10:50 AM
  #446
1990 300ce 24v I6
My email to Magnaflow if anyone wants to read. I think I made a good case for us (minus the spelling errors), any thoughts?
Originally Posted by Private Email to Magnaflow
Thank you for processing the application guys, and perhaps I should take this time to explain why an older, non-performance MB was suggested to you.
I think the main reason is thus: Currently, japanese cars (regardless of quality and capability) are highly over-valued in the US market. Look at the absurd tuning scene for things like Civics and other cars that were never meant for anything other than cheap commuter cars.
At this point in time, the w124 (300e, 300ce, 300te, 400e, and lesser extent 500e) are all coming down in value so sharply that a 300e can be had for around 2-3k in great shape.
The I6 engines (m103 and m104) have some tuning potential as they have previously been massaged by Renntech, AMG, Brabus, and with aftermarket ktis from Mosselman, TurboTechnics, and other manufacturers in the w124's heyday.
At the current price point, these vehicles find themselves in the hands of younger (23yr old) people interested in racing and tuning. I am one such person. I've already taken my 300ce to a few AutoX meets and have begun to tune the car for performance (suspension first). It has already run a 160mi Off-road dirt rally called the Pine Barrens Express in New Jersey. In it, I finished 9/53 overall as the first Non-SUV and the first RWD car. The closest STI was 15th place.
From the factory, the m104 in the 300ce does 0-60 in about 7.8s (Mercedes is always conservative with their numbers) and puts out about 217hp and 221ft/lb of torque. It produces these numbers very late in the RPM range (starts to pull hard after about 3.5k till about 6k).
I'd be very, very interested in seeing a specific dyno-tuned and proven exhaust for the m104 300ce that would guarantee me a bit more low end grunt for things like AutoX and rally where I won't be seeing 120+mph. I know that a few other w124 owners would be interested, especially as many (as I have) will have to replace their exhaust in part or in full due to regular aging and wear. I had looked at your products two summers ago when my exhaust rotted, but there was nothing available to me.
Another w124 owner has applied with a m103 300e. This engine is similar to the m104 but is only a 12v instead of 24v engine and behaves a bit different. He is fortunately about 5-10 minutes from your factory and has both that car and the m103 300te (wagon). I do believe that if you are interested, we would be able to find volunteers across the entire w124 range.
w124 owners are typically VERY passionate about cars in general, and the w124 in general, and though we demand high quality, we also are interested in the somewhat elusive "performance" tuning capability of the m104 and m103.
I believe that with your help we could help push the w124 as a possible candidate for tuning and other Automotive enthusiast activities as I have tried to do by making my presence in AutoX meets and other places where quite frankly, I'm made fun of relentlessly. However, I typically do well enough that some without severe pride issues later eat their words.
Thank you sincerely for your time and consideration,
Brett Carlock
Old Jun 8, 2010 | 09:18 PM
  #447
AMGDave's Avatar
300D, 500E, E420
I would not expect any serious power gains from exhaust mods... I'd be impressed if the custom system showed a 10hp gain. The stock exhausts flow surprisingly well, even on the V8 models. I'd love to be proven wrong though. Serious power will come from forced induction. Anything else will be incremental (read: miniscule) without major $$$, i.e. displacement increase, porting/flowing heads & manifolds, custom cam, etc. Some of those things trade low-end torque for high-end power which is not always good.
RENNtech is a waste of time - they have no interest in anything W124, unless you are asking about some old stuff they want to get rid of anyway. Their prices are usually exorbitant as well. What did you have in mind from them, btw? I assume you have seen their old W124 catalog here already?
Old Jun 8, 2010 | 10:19 PM
  #448
1990 300ce 24v I6
Yeah, me either. But, if they're willing to prototype, test, and dyno even a few HP is welcome.
I donno, they've been civil with me at least. Yeah, I looked at your catalog and that is what prompted me to ask.
I've been told that they can put together the parts for the 3.6L build for about 7k and that the rest of the work will be another 4-5k. About what I expected (realistic) more than I had hoped though.
Sounds about like what a proper twin-turbo install would cost.
Old Jun 9, 2010 | 01:55 PM
  #449
1990 300ce 24v I6
Giant rims are giant. I have never really visualized the size of 20" rims until this picture, but my god...
They're off my Uncle's Shelby GT500 if anyone is interested.
Old Jun 10, 2010 | 10:21 AM
  #450
AMGDave's Avatar
300D, 500E, E420
I've been told that they can put together the parts for the 3.6L build for about 7k and that the rest of the work will be another 4-5k. About what I expected (realistic) more than I had hoped though. Sounds about like what a proper twin-turbo install would cost.
Have you thought about just swapping in a C36 motor? It would be far cheaper than building a 3.6L from scratch. Even using the C36 bottom end (or long block?) would probably save a ton of $$$. Better yet, swap in the whole C36 engine management system (HFM) like Neil V did in his 360TE AMG Uberwagon.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
