What do you guys think about these wheel sizes?
Old Jan 13, 2007 | 05:28 AM
CDP's Avatar
CDP
W124's
17 x 7.5" ET 36 in the Front.
17 x 8.5" ET 34 in the Rear.
So, being that I gave you the wheel sizes along with the offset - what do you guys think about the size on my 1995 E420?
Old Jan 13, 2007 | 10:33 AM
jdmfiend's Avatar
conservative.
why dont u run lower offsets?
Old Jan 13, 2007 | 05:43 PM
CDP's Avatar
CDP
W124's
Those are the only offset it comes with - Think I'll run into any fitment issues?
Old Jan 13, 2007 | 08:00 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
I am not an offset expert, but I would say that 17's are perfect, and that if you go wider than 7.5" in the front, the suspension doesn't feel right, as in the feel of the steering, they also tend to train rail on rutted hwys too.
Old Jan 13, 2007 | 08:36 PM
jdmfiend's Avatar
are they works?
my wheels came +38 and before i put the spacers on, they rubbed against the brakes. i ran 10mm spacers in the front (which pushed the offset to +28) and 10mm spacers in the rear (which made it +23). you may run into fitment problems, but thats nothing 5/10mm spacers wont fix.
Old Jan 13, 2007 | 10:58 PM
rooney2006's Avatar
1991 300E
From what I've heard, the oe offset is +35
Old Jan 13, 2007 | 11:32 PM
CDP's Avatar
CDP
W124's
Nice - I'm going to check up on these wheels and see how they fit on my car - If it looks good then I'll get them and reveal it to you guys.
Old Jan 14, 2007 | 01:15 AM
McBear's Avatar
500E's
Correct offset on the W124, except 500E is 35 for the 17" rims. You will have no problem with those offsets and 7.5 front and 8.5 rear will set the car perfect. just insure that your tire sizes stay within a couple of % otherwise you can trigger the ABS since it will think things are hosed up. I have not experienced this but have been told that you want to keep within 3%. You can go to several sites to profile the overall circumference of the tires to make the determination. Base your calculation off the stock 215/45-17 which is the 17" equilvilant to the 205/60-15
Old Jan 14, 2007 | 04:13 AM
ZorroAMG's Avatar
Enzo, my Benzo
17's? Why?
Old Jan 14, 2007 | 04:50 AM
CDP's Avatar
CDP
W124's
I can get a good deal on them now since I work at the benz dealership.
Just going to get them for the time being - OEM = Clean Look.
McBear, I know what you're talking about in regards to trigging the ABS light and etc. The wheels I have now on the E420 does that sometimes ever since I put on the Hammer wheels. Know how to fix it? The light gets annoying when it comes on.
Old Jan 14, 2007 | 10:18 AM
ShanMan's Avatar
'95 E420 SE
I am running 17 x 8 x et35 at all four corners. They look very nice, but unfortunately I am also running 235-45 tires at all four corners. They are great in back and fill up the wells nicely, but they rub everywhere in front. I will try 225's next time....or sell my wheels and get 7.5's.
FYI...I have never had the issue with anti-locks that you guys are describing.
Old Jan 14, 2007 | 11:15 PM
McBear's Avatar
500E's
Is the problem the Hammer wheels or a differential between front and rear tire circumference?
I am getting ready to put a set of Aero1 Hammers on the Sportline [even though they weigh abit more than I like] but will be putting same tires front and rear.
I will talk to a couple of people here to see how to resolve. It has to be a threshold on the ABS if it is a tire circumference differential. If so, finding what the % threshold is and massaging it would be the solution.
Old Jan 15, 2007 | 12:40 AM
rooney2006's Avatar
1991 300E
FYI...I have never had the issue with anto-locks that you guys are describing.
Just run 215's and you won't have any problems with rubbing at all. The 17x8 isn't a problem with the right tire.
Old Jan 15, 2007 | 10:08 AM
ShanMan's Avatar
'95 E420 SE
That is the second time I have been told that, so I fully concede you guys are right. I'm not a big fan of the rim bead being wider than the tire though...any chance you have a pic of your car showing how your setup looks?
Thanks again for the education BTW.
Old Jan 15, 2007 | 10:19 AM
Bigpete123's Avatar
1990 300ce
myfirstbenz is correct about the 8" wide tires... mine make my car hug every single rut on the road. but they look nice!!! lol
Old Jan 15, 2007 | 10:44 AM
rooney2006's Avatar
1991 300E
i can take some later. I would agree about the suspension though... It does feel funny with the 8 inch wide wheel. I just got my Vogtlands today in the mail, so I'm going to try to get them installed and then we'll see how the 215 tire looks.
Old Jan 15, 2007 | 03:14 PM
oneill_1's Avatar
MB 300E | BMW M Coupe
hey chris, what rims are you planning on getting? i would comment on the rims and offsets but i dont know much about that so i wont...haha, sorry.
-OG
Old Jan 25, 2007 | 03:39 AM
autosleek's Avatar
hi there! any news regarding the wheel fitment? I am also trying to do the same with my car. how did it go? did the rear fit pretty good with the et30 offset?
Old Jan 25, 2007 | 06:58 AM
CharlestonN's Avatar
03' CL55 AMG
I run 18x8.5 rims in all 4 corners of my car with 225/40 tires and it handles and rides beautifully and only rubs if i hit an unexpected dip or speed bump, not sure what the offset on these wheels is though, the only real negative i can think of is that they do tend to rail onto grooves in the road
Here is an offset calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jan 25, 2007 | 09:14 AM
V9.'s Avatar
V9.
W124
The C36 and C43 AMG monoblock rims have those offsets I believe. I think the 2000clk 430 with sport package have offsets of 35 front and 30 rear for the same rims. There seems to be a lot of confusion on the board as to which set would work better on a w124. Anyone want to clarify?? I believe AMG (Monoblock) list these as fitting a regular W124....17x7.5 ET42, 17x8.5 ET30 (rears).
Personally I'm getting the RH AA topline in 17x8 et 35 and 17x9 et 29. See my other post.
