Faulty ecu (e300 2.6 1991 80K)
W124 280E and a Mini R50
Hi guys!
I'm really desperate to solve the uneven idle when engine gets warm. Thought it might be the oxygen sensor, replaced but no luck. Just to let you know I've checked (and/or replaced the following):
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
lamba sond = oxygen sensor (new)
chekced the injector seals
injector cleaner (3 bottles)
OVP relay
and probably a couple of other minor things
Now I'm running out of ideas...could it be the ECU? I had no idea the car can actually run with the ecu disconnected (runs rougher than usual but I did have it running with the disconnected Jetronic ECU in my hand!). Do you know if the ECU is likely to pack up?
Hope to get it fixed....hope you can help! I do like the car and want it fixed once and for all!
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
OVP relay
No way, spark plug leads (HT leads) are brand new quality parts.... and checked the car in the dark, even sprayed some water to see if it sparks...
is a German Tank
Hi guys!
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
is a German Tank
Hi guys!
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
OVP relay
Spark plugs (new)
HT leads (new)
distributor cap
rotor arm
fuel filter (new)
OVP relay
If so, that may the culprit.
My next guess ie seither the ECU or Air mass meter + fuel distributor + throttle body combo..... or maybe the temperature sensor...what do you think?
1995 E320 SE, 162,000 Miles (Sold)
From what I know about K-Jet systems in general, the ECU basically modifies the air/fuel mixture using the readings from the Oxygen Sensor and probably some other inputs. It is strictly for emission control, or so it was on my cars with K-jet (the latest of which was a 1985 Volvo Turbo). It is a fairly simple, electro-mechanical (as opposed to electronic) system. If it runs rough without the ECU, look for :
1. Vacuum leak, leaks at idle control valve hose- most likely
2. Intake manifold gasket leak (another form of vacuum leak)
3. Is it a rhythmic miss, as in just one cylinder not firing at idle? if so:
A. determine which cylinder it is by disconnecting spark plug leads until you find the one with the least change.
B. Double-check the obvious, like the plug and wire.
C. Spray WD-40 around the intake in that area, including injector seal (I don't know if you checked them this way or some other, but this works)
D. Swap the injector with another and see if the miss follows. If so, replace the injector.
2. Mixture too lean (not enough fuel) There should be an adjustment for this but don't screw with it until you've checked everything else. Remember where the adjusment screw was so you can put it back if necessary.
My Volvo had this problem and it was a bad intake manifold gasket. The turbo boost had blown one of the rings around a cylinder. I wouldn't think this would happen on a non-turbo engine, but who knows.
Good Luck!
Good Luck!
1989300CE(sold),1996Accord,02CBR954
Check the inside of you distributer cap.Sometimes theres a green build up that forms.I just scraped that build up off of mine which hepled idle abit.I read somewhere that youre suppose to change the o rings inside the cap. Which I didnt, I just reused the old one.So i think I will order a new cap.And do it right , clean that oily film out and replace the o rings.
So, did you try the misfire test? Is it like a misfire or just "uneven"? Does that mean it goes up and down like it's hunting?
'86 300e
The ECU is not likely to be defective - can happen but not frequent. Your problem sounds not unlike mine - except mine goes away. If the car runs ok cold but starts running rough when it warms up I suspect the temp sensor (amongst many other possibilities) - you could try removing the wires and crossing them - the ecu gets a low resistance signal from the sensor when it gets up to running temp and adjusts the mix accordingly. Or you could test the resistance from the sensor - i think about 6kohm cold, 300-400ohm warm.
Bon chance.
Bon chance.
Bon chance.
Bon chance.
'86 300e
theres a temp sender for the gauge in the dash, and another one at the very back of the head for the ecu - are you sure you're checking the right one?
BTW, I've read here that achieving a smooth idle on the M103 engine is alsost impossible, but I don't know why it should be.
'86 300e
yeah, vacuum hoses can cause chaos - the one at the back of the engine that goes to the tranny has a habit of coming out causing rough running and erratic gearshifting - my mechanic pointed that one out to me the first time i saw him cos he gets sick of people getting their cars towed in for a fix that takes 15 seconds...
Guess you may be right...I've ordered the temp sensor just in case (it's only $40). I guess during the previous service (almost a year ago when it all started) the garage may have tried to adjust the mixture (looks like the tamper-proof plug is missing from the mixture adjustment on the throttle body). I'll have to put it on an ehxaust gas analyser and see if I can fix it anyhow... I managed to locate a throttle body / air mass meter / fuel distributor unit from a working 260E fot $160 so it may also be an option...
atf in power steering is a bad idea mister. Your lovely vehicle takes power steering fluid.
My m103 is running dead smooth but idles a little low. Few things I did... Injector seals are a must, check for brittle vacuum lines and especially the connectors. The idle control valve has 2 big rubber hoses coming out of it, replace those, that made the biggest difference and while doing so, flush your idle control valve with throttle cleaner(black gooo will come out of it for sure).
You said your engine was shaking, often if a motor mount goes flat, the engine will shake like a seizure. If you have a sticky injector, that will also shake the engine like crazy. Another issue could be that you have loose rocker arms and a cam going flat, check for that.
'86 300e
hows it going?
if the mixture screw covers been removed - uh oh...when i got my car some moron had actually busted the mixture screw housing f..ing around with the mix - i had to get a whole new casing fitted
