Has anyone done the "resistor delete" mod?
1995 S14
I read that Rick of 2phast.com, a 500e owner, did a modification to his car in which he removed a resistor to free up the throttle as well as some HP. Has anyone done this to a 400E or 300E? If so, how do I find the resistor in relation to the battery? Thanks in advance.
1995 S14
Well, I took it out and gave it a test drive this morning on my way to buy the mom some flowers, and I am pleased to say the throttle response IS better. I know some people argue that this mod does nothing (even a MB tech), but it has given a bit of a boost in throttle response in 2nd and third gears. I am monitoring the engine closely just in case, but I think if I just keep on using 92 octane, I will be fine. Give it a try, for W124 owners, the resistor is kind of under/in front of the brake fluid resovoir attached to the firewall. It is wrapped in electic tape and is easily detached, just don't forget to recover the open plg with tape. I may get a dyno to see if there are any true increases, but I am about 99.9% sure the response is more sharp.
2008 BMW 328i
Well, I took it out and gave it a test drive this morning on my way to buy the mom some flowers, and I am pleased to say the throttle response IS better. I know some people argue that this mod does nothing (even a MB tech), but it has given a bit of a boost in throttle response in 2nd and third gears. I am monitoring the engine closely just in .
1995 S14
2008 BMW 328i
1995 S14
It's just a noise the engine makes that is a reflection of using bad or low quality gas. It is not a big deal, it can be fixed with using premium gas (whick you should do already ). I have been driving resistorless for two days now and no problems. I love the feel of take off now, it just feels a lttle more "quick". Don't expect your car to burn rubber off the line, but it is a noticable change.
is a German Tank
Dora the Explorer
500E Signal Rot
Please refer to the original thread here
http://mercedesshop.com/shopforum/sh...iming+resister
M104 has reference resister, but its location is different on the W124
FINALLY an answer!!!
If the M104 on an E320 has a resistor, does anyone have an actual photo of it? Alon, aka Ashman's link to the PDF file is no longer active.
Thanks in advance!
Thanks in advance!
1995 S14
1995 S14
I have not done a formal check, but it seems to be the same if not better. That could e me, but I usually go through 1/4 tank every two days, and I am still only down about 2/6 of the tank. This could have nothing to do with it though .
The only engines that will have this resistor will be cars with an EZL. This means if you have a 94-95 E320 with HFM, you do not have this resistor. The old M104 with CIS-E and EZL ignition has the resistor. Your HFM engine runs much better than the old CIS cars anyway. I would much rather have the HFM fuel injection than the ability to do the resistor mod.
RESISTOR or NO RESISTOR on a 94-95 W124...? That is the question...!
Ok, anyone else want to clarify...? Because this now totally confuses the entire subject altogether.
When I had my 190E, I found what was describe by Rick(2Phast's) write up on his website.
I've been reading and researching all over the different boards/forums and I'm even confused more now, than I ever was.
