vaccum
Old Feb 17, 2008 | 01:06 AM
spmbass's Avatar
1987 300E
vaccum
hey my heat hasnt been working 4 a while i thought it was blow or reg but when i pulled out my glove box to install my satelite radio i found to side by side black vacum lines with colored tracers on them i believe. the lines were just hanging there not plugged into anything is that normal, has anyone ever seen the inside on the glove box
Old Feb 19, 2008 | 10:41 PM
spmbass's Avatar
1987 300E
no one knos
Old Feb 19, 2008 | 10:47 PM
jmoney6's Avatar
1993 Mercedes 300e 4-matic (m103 motor)
yeah, my roomate has an 88 300e, I replace the box for him and saw that too. I can get you the colors and where they match too tomarrow if you want
Old Feb 20, 2008 | 07:49 AM
spmbass's Avatar
1987 300E
yes please
Old Feb 20, 2008 | 08:16 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Possible why your heat hasn't been working.
Heat and A/C flaps are vacuum controlled.
Old Feb 22, 2008 | 05:35 AM
vahagn's Avatar
Hi there! Looks like I have similar problem. My 90 W124 E300 blower gives cold air on entire left side of the vehicle's saloon and hot on the right side (on all modes). When the blower in on low mode or when I just switch on the blower (after engine is hot enough) it gives hot air at the beginning, but then it gets cooler and cooler. When I turn off the blower at the end it gives a little hot air.
I didn’t know that the heating is vacuum controlled. Is there any diagram/scheme available? Thank you.
Old Feb 24, 2008 | 12:38 AM
spmbass's Avatar
1987 300E
any answers!
Old Feb 24, 2008 | 09:09 AM
RBYCC's Avatar
any answers!
I'll try one more time.
The climate control flaps are vacuum controlled.
You have vacuum lines hanging.
Unconnected lines means your flaps aren't working.
Doubtful the lines have fallen off the individual flap operators.
More then likely from the distribution manifold.
Look to the area behind your climate control panel above the radio.
Should be a disc that has nipplies on it.
Push the hoses on to the nipples and see if your control works.
You may have to swap hoses around until you get the correct locations.
