95 E320 fan rubbing
Old Feb 22, 2008 | 03:07 PM
golfinator's Avatar
95 E320, 2002 E430
95 E320 fan rubbing
New member and thanks for the web site!
Radiator fan blades are rubbing against a/c compressor pulley. Could this be a motor mount, tensioner, or some other pulley gone bad?
Thanks for your reply.
Old Feb 22, 2008 | 07:43 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
First wellcome to MBW
Old Feb 22, 2008 | 07:45 PM
tanktube67's Avatar
check your motor mounts
Old Feb 22, 2008 | 09:48 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Off the top of my head it sounds like worn fan carrier bearings. The fan is not attached to the water pump as it is on many cars, it has its own bearing. If that bearing were worn I suppose the fan would be tilted closer to the AC compressor. You could remove the belt and see if the fan/pulley bearing is worn (it would have a lot of free play) or the bearing mounting bolts are loose.
Old Feb 23, 2008 | 10:00 AM
golfinator's Avatar
95 E320, 2002 E430
Thanks. The fan bearing is hard to turn. Don't see any record of it being changed over the past 232k mi and will do so.
Old Feb 23, 2008 | 11:28 AM
shdoug's Avatar
I forgot about the fan clutch. That part is much more likely to be the culprit. There is some info here about that job, as there was another guy who did it. Sounds a bit tricky so don't get in a hurry with it.
Old Feb 24, 2008 | 07:55 AM
golfinator's Avatar
95 E320, 2002 E430
Thanks, will do. New mounts installed about 40k mi ago.
Old Feb 27, 2008 | 05:06 PM
golfinator's Avatar
95 E320, 2002 E430
Replaced the fan bearing/bracket,fan clutch, idler pulley and belt. That took care of the problem. Fun job! Wish I had that "special tool" that holds the fan pulley when you're trying to put 33 lbs. on the clutch assembly bolt.
Old Feb 27, 2008 | 06:40 PM
shdoug's Avatar
Thanks for the update.
