87 300E Auto to 5-speed swap?
Old Mar 2, 2008 | 03:17 AM
dead_lemons's Avatar
87 300E
I have found a local 300E 5speed transmission. I was wondering if it was possible to swap out my auto and put in the 5speed. And if it is possible how much would it cost.
Old Dec 27, 2010 | 08:53 PM
Rogue's Avatar
1991 Mercedes 300E
BUMP---bringing this thread back to top because I am VERY curious about the feasability of doing this as well...
Old Dec 28, 2010 | 05:44 PM
Hanno's Avatar
6.9
Thumbs up
do a search here, also in the parts forum of peachparts dot com.
Old Jan 8, 2011 | 11:26 PM
1987AMG's Avatar
1987 AMG 3.2 (5spd manuel), 1981 240D (4spd manuel)
I have recently done this to my 1987 300E. I have. 3.2 AMG with the M103. I did it in just a day. First you need the drive shaft from the 5spd if you don't have it your out of luck! Everything will bolt up right but you will have two wiring issues 1st the neutral safty switch. 2nd the back up lights. You will also need to get the woodgrain center piece about $150 (USdollar)new. And a rubber boot. I can help any way I can. Last you will need a new clutch hard to find and expencive it cost me $450(USdollar) and flywheel turned. You will also cut the pre preferated line for the clutch from the brake fluid box. And you will also need the clutch/break pedel assembly. If you get all thoes it will be smooth saling. PM me back if you need help
Old Jan 9, 2011 | 10:02 AM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
I did mine as well. I thought of doing a write-up but realized that someone had done it before and published it at the following link. http://www.club124.net/performance-upgrades.html The two main take-aways from my own project are: (a) if you change the differential as well, make sure you also find a matching speedometer. Otherwise, the speedo reading will be inaccurate, and casually buying any instrument cluster off eBay claiming to fit would be a waste of money and time. (b) the clutch travel distance of the factory pedals is too long and is almost unable to adjust.
Old Jan 9, 2011 | 02:27 PM
bsmuwk's Avatar
Depends on the day
ah see that website i made for fun, i've since decided to make a more thorough DIY with part numbers and a weak write up: http://mymbonline.com/forum/viewtopic.php?t=26497
it should be the 4th post down in an attachment
Old Jan 17, 2011 | 04:36 PM
fredtga's Avatar
w202
i have a full 5 speed swap available for sale if anyone's interested
Old Jan 17, 2011 | 04:41 PM
1987AMG's Avatar
how much??
Old Jan 28, 2011 | 12:56 AM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
PM me with a price you have in mind.
