Look to this video Clip and tell me what is the problem
Old 03-02-2008, 06:35 PM
anas2912's Avatar
Mercedes E 320 1994
http://www.youtube.com/watch?v=5QwLxkUKOsg
Mercedes E 320 1994
5 speed
(normal acceleration in the 5th Gear.)
The Question
Why the car can not exceed 56 RPM , Is this normal or something problem ?
thank you
Old 03-02-2008, 06:53 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold)
Mercedes E 320 1994
5 speed
The Question
thank you
Are you sure it's a 5 speed? I thought the '94s were all 4 speeds. Are you using good non-resistor, non-platinum spark plugs?
Old 03-02-2008, 07:06 PM
GORBETTTEAM's Avatar
'95 3.2 M104
Cool
are you saying that that was acceleration in 5th gear????????????? looks like 3rd to me. anyway. of course i might be wrong but check kick-down solenoid valve, kick-down switch and fuel pump relay OR adjust control valve full throttle set screw approx 1-2 turns in clockwise direction. good luck.
- gorb -
Old 03-02-2008, 07:18 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Looks like 2nd to me :-/
then again, i have a 4 spd.
Old 03-03-2008, 06:41 AM
anas2912's Avatar
Mercedes E 320 1994
Thank you for a fast reply
this video showing 5 speed of my car
http://www.youtube.com/watch?v=mVF7rOOrNrs
Normal acceleration in the D5 ( sorry I am not specialist in car field )
I used Genuine spark plug ( champion ) from the Authorize dealer.
Yes, Non-platinum spark plugs .
But non-rsistor( I am not sure exactly about this)
.I will ask the dealer and reply later.
Can you pls show me the position of solenoid valve and control valve... because I want to check it .
Old 03-03-2008, 06:43 AM
anas2912's Avatar
Mercedes E 320 1994
Yes , it is in the 2nd ....( sorry for the mistake I am a beginner in car driving)
Old 03-08-2008, 05:15 PM
anas2912's Avatar
Mercedes E 320 1994
This is a spark plug
http://www.beru.com/english/produkte...&action=step04
The first one with designation (14 F-8 DU4)
I change the Kick-down Valve and Fuel Pump Relay
The car become much better for going 1 Gear back during moderate Acceleration
But with Full Acceleration Cannot Be ( Cut off will happend for RPM ) as seen before.
Iam not sure about ( control valve full throttle )
Can any body show me it's place Where is it ?
Is it possible from Oxygen Sensor ?????!!!!!
Old 03-08-2008, 07:06 PM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Plugged up cataletic converter?
Old 03-08-2008, 07:41 PM
STLe320's Avatar
95 e320...sold the rest
Hold on, hold on...
I'm rather confused as to what the problem really is?
From your video...it looks fine to me man..
Old 03-08-2008, 11:18 PM
shdoug's Avatar
That not normal. The engine looks like it's topping out around 5600 RPM. It should be able to go higher than that. Mine always shifted right at the redline so I don't know what it would have done if it had been able to reach the redline.
Old 03-08-2008, 11:44 PM
GEDaggett's Avatar
1994 E320 (current)
Mercedes E 320 1994
5 speed
The Question
thank you
Clarification please.
From the video you are rolling at about 30kph and then you punch it. Your engine is topping out at 5600rpm and around 85kph. Will it not shift? What position do you have the gear selector in. When was the last time you have your trans fluid and filter changed?
Old 03-11-2008, 05:23 PM
anas2912's Avatar
Mercedes E 320 1994
I am not sure of catalytic converter
Old 03-11-2008, 05:26 PM
anas2912's Avatar
Mercedes E 320 1994
Originally Posted by STLe320
Hold on, hold on...
The problem is cut off for the machine when it reach 56 RPM
Old 03-11-2008, 05:30 PM
anas2912's Avatar
Mercedes E 320 1994
That's right
My car looks like your car color , But yesterday I drop it at workshop to change the paint to Flint Grey Metallic and will be finished within 2 weeks
Old 03-11-2008, 05:36 PM
anas2912's Avatar
Mercedes E 320 1994
Position S = Sport
I change the trans fluid and filter ( Genuine from the dealer ) two weeks ago
The car did not shift ,
I know that when you punch the machine it will reach the red line then shift to the next
Old 03-27-2008, 07:13 AM
anas2912's Avatar
Mercedes E 320 1994
Another video
Today captured
Starting from Zero
http://www.youtube.com/watch?v=JuQI2xybOXY
Old 05-08-2008, 07:19 PM
anas2912's Avatar
Mercedes E 320 1994
NOW IN THE 1ST AND SECOND GEAR AT 42 RPM AND THE 3RD AT 56 RPM
NO BODY SOLVE IT FOR ME
ONE MECHANIC SAID THIS FROM DISCONNECTION IN THE ICU CABLE !!!
BUT I THOUT IT IS FROM ASR
IS THAT RIGHT
Quick Reply: Look to this video Clip and tell me what is the problem
