help ....fuel & oil additives
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
hello everybody, i just purchase a 1992 300e, is it safe to add a fuel injector cleaner,to the gas tank ( to clean the injectors & fuel lines) & engine oil treatment to clean the valves & gunk inside the engine compartment,
Any suggested brands![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I've done it with my 300ce a bunch of times. I've used STP and prestone with no ill-effects. In fact, it does seem to help a little, if only for the extra octane they sneak in those things
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
We used that to help get my gas gague un-stuck on my 300ce, it worked wonders! Now my gas meter no longer jumps all over the dial. My dad also used the Lucas ATF stuff and it cured a leak in the AT of our Explorer.
WOW thanks guys, how about SEAFOAM & Berryman, additives? is it safe for the 300e?
the seafoam i used it on my 1979 diesel, & it worked great ( can be use in gas cars too ) and the berryman i used it on my 1990 galant Vr4, that work verywell
thanks for the suggestions
Seafoam
added to one half tank of gas a year,put it in on low and fill the tank half way.Put it in your oil a few days before oil change,every other oil change.
ohlord
ohlord
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
lots of cars
Don't run your car low on gas and add additives. It will clog your fuel filters and your injectors. Always refill when it's at 1/4 tank left. If gas prices are hitting you hard then fill with 87 and your car will run fine with one bottle of fuel additive a week. You can add 91 octane once in a while to mix it with your cheaper gas. I use STP fuel system treatment because it's 99c at this store by my work.
89 300TE, and 68 280sel
+1000 for Seafoam. I put some in the tank, some in the oil, and let the engine suck some into the intake vacuum hose to clean the backside of the valves..... the best!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
W124
Be careful, too much injector cleaner/fuel system cleaner/gas treatment can damage your catalytic converter. Even though the bottle says it won't do damage it will. Every tank is excessive, I like to put some in every time I do an oil change.
