Thermometer calibrate
Old Jul 11, 2008 | 10:44 AM
timsvt's Avatar
1994 E320 Wagon
Does anyone know of a procedure to Calibrate the Thermometer on the instrument panel? Mine says its 177 degrees F and im pretty sure its not. haha.
Thanks a lot guys.
Old Jul 11, 2008 | 02:57 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Good question, mine is reading about 97-100F at 5am in New Jersey, which it most certainly is not :P
Old Jul 11, 2008 | 03:39 PM
elms3's Avatar
87 w124 300E
I'll throw another in just for *****s and giggles...
134F and i still CAN NOT fry eggs on my hood...
Old Jul 18, 2008 | 07:45 PM
mr300ce's Avatar
1990 300CE
The sender is probably bad. Not sure where it is located, but most cars its out by the grill in front of the condenser and such.
Old Jul 18, 2008 | 08:20 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
The temp sensor is attached to the front license plate frame. If you remove the plate you will see it. There is no calibration for it so it is probably defective.
Old Jul 18, 2008 | 09:04 PM
mr300ce's Avatar
1990 300CE
Perhaps, if you don't find the sensor out front, someone either moved it under the hood, or removed it.
Old Jul 18, 2008 | 10:19 PM
timsvt's Avatar
1994 E320 Wagon
Thanks a lot for all the help guys.
Old Jul 19, 2008 | 03:02 AM
rayhennig's Avatar
300CE 24V Sportline 1991
It's the sender
Yes, I agree with shdoug.
Years ago mine would sometimes flash 55 (Centigrade) and then disappear. I replaced the sensor with one recovered from a donor car.
Recently, the same again. 55 and then dead.
A new sensor is on the way from Berlin so I hope to have it working again next week.
Good luck.
RayH
Old Jul 19, 2008 | 12:47 PM
1990 300ce 24v I6
ABout how much do they cost, and do you have the part number?
Old Jul 19, 2008 | 05:44 PM
timsvt's Avatar
1994 E320 Wagon
Looks like Autohausaz has them. About 70 bucks.
