Did I screw up? 215/50/17
1 Post
97 S600 coupe/gf 16 C300 Lux. Former: 08 GL450, 83 300D, 97 C230, 08 c300 luxury, 92 500SL, 93 400E
I went with these as opposed to 45s because I thought they would look too small, and also my speedo/odo would have read more mph and miles than with 50s. Oh yeah, I figured they would ride softer as well.
First off, the thing looks like a 500 with these things! I had bigger tires on the same size wheels on my old 202, and they didn't look nearly as substantial as on this 400e.
Problem is, there is a slight rub on the LEFT front when going over dips. No rubbing when turning the wheel, nothing in the rear, just the left front. The overall diameter is just .5" more, which means .25" around - I just can't imagine that is causing the rub - you think I have a bum shock/spring? I know they are original, and the shock bushings are cracked and brittle.
My first order of business is probably going to be Bilstein HDs - unless you think I need 45 series rubber
1 Post
I don't wanna do that. Also, they don't stick out that far - they are flush with the fenders, tread curves inward staying inside them. May be hitting the plastic body cladding, but again, it's only happening on left side
Who has run a 215/50/17 on this chassis?
Rolling fenders gives you leeway in this and other wheel decisions...
But fwiw, when my white Sportline first got the currrent 18x8 Aero IIs, the driver rear wheel was rubbing a little. After the rear rubber anti sway bushings were replaced, no more rubbing. Visual inspection showed they were moderately worn...
1 Post
1 Post
15 year old shocks in all likelihood will sit lower due to leaks/worn valving, no?
Not only that, but the only rubbing I get is when I hit a dip in the road. It's hitting either the plastic cladding or the wheel well liner - it sounds clearly like plastic. The HDs will keep it from dipping and rebounding as much, which would be my theoretical fix
1 Post
I should know that answer for sure, shouldn't I? I CAN tell you it is either 37 or 35 - I will doublecheck in a bit.
Again, the only rubbing that occurs is when the wheel is pushed upward or the car settles from cresting a hill. Going through a parking lot, turning to full-lock, there is no rubbing at all.
The wheels are AMG monoblocks, 17x7.5, that were previously installed on a 210 - I am not sure of the original donor, but it's almost certainly a C36 as they are non-staggered AMGs
1 Post
No, it is. Just took it out again, and looked at it. On substantial dips/undulations, the tire has been rubbing a 2inch by 1/4inch area on the front of the plastic lower body cladding BEHIND the wheel (not the bumper cladding - sorry, I know it may be confusing) And again, it's only the left side. The right is not making such contact. Something has to be worn in the left front suspension, either the shock or a bushing ( I suppose a spring could be cracked as well)
92 500e, 95 E34 525I Touring
Not confusing at all. I experienced the same thing when I upsized to 17's. I was able to slightly file down the plastic enough to keep it from rubbing, but I assume you do not want to do that. Looks like stiffer springs or new tires may be your only options.
1 Post
FWIW, the new setup looks awesome and rides even better. Feels more solid, quieter, steering response is very nice and crisp, and tracks perfectly.
