replacing the valve steam seals on my 300e
87 300E, 82 300SD, 85 380SE, 1969 230,
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
hey guys i feel really down and out on my 300e that i recently purchased not knowing that it burns alot of oil i need to put a quart in it if i am to drive from my house in northern California to los angeles which is 430 miles, it currently does not pass smog because the catalytic converter is caked with oil.. I am wondering if its more then just the seals the car has been restored on the exterior, sporting Staggered 17" AMGs (which scrape on the back) I really love my car and I would love to have it running well.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1 Post
1989 190e
How many miles does your car have? Mine needed to have the valve stem seals replaced at about 140,000 miles, mainly because of the way I drive FYI... anyway if your milage is getting up there it is a safe bet that the stem seals are brittle and need replacing. Just don't try to do the job yourself, I learned the hard way that you need to be extra careful not to break timing guide rails when removing the cylinder head ![slap](https://mbworld.org/forums/images/smilies/slap.gif)
As for the catalytic converter... Really your only choice is to get a new one. You can go aftermarket (i.e. magnaflo - $90-$100) and get a universal cat, have an exhaust shop do the work (about $100) and they will usually buy your old cat for like $40 or $50.
90 300E, 03 E55 Black designo, 06 IWC CLS55
Hey guys Ive got a little good news that i picked up last year on one of these forums. You DONT need to remove the cylnder head to change the valve stem seals. I will come back with some info on exactly how to do it, but if you search here you may find it. I know how to do it physically but just dont know the technical terms to describe it here!
However, my car only has 130k miles and I changed the stem seals but I found my plugs were still getting oiled up badly that was one of the several reasons that it was rough running. So I suspected the valve guides were worn out. So, removed the cylinder head and put it on a table. Removed the intake and VOILA! I found LOADS of oil in the AIR intake for cylinders 4,5 and 6! This was causing the biggest problem. So sent the cyl head to a machine shop, they changed the valve guides over (need special machine/process) and skimmed the cyl head and put in yet another set of seals. My friend and i took out the head and put it back on the car. No need for an engine hoist, just a few tools and a screw with two nuts and washers on that removed the retaining pin in the front of the head (some people use a slide hammer, but i didnt have this). That problem was solved, but i still have a problem with my 9.8mpg fuel consumption, which is an unrelated problem!
surprisingly the car has plenty of power and idles very smooth although it is an 87 with 165k on it maby I should just pull the head and have it done right the first time but it would be nice if it was just the valve steam seals. My only fear is that theres a worse problem like the rings are going bad.. but that doesn't seem to happen very often in a mercedes.
99 ML 320, 97 Porsche 993 C2S, 92 300E
I wrote a DIY article a few years ago for this job. See link.
http://www.mercedesshop.com/Wikka/M103ValveSeals
1 Post
1989 190e
The reason I pulled the head on mine was because
1. It's easier IMO to change the valve stem seals this way
2. you can check for other problems like worn rings, scored cylinder walls, valve guides, vavle wear, replace the head gasket, maybe have the valve seats ground. My theory was to get all this stuff off the list while I was inside the engine anyway...
3. Look in to a port/polish while you have it off![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
But you definetly want someone who knows what they are doing, because the last thing you want is to have problems again further down the line.
well i wish i had that kinda money right now but i gotta pay for insurance $650 for 6 months
stupid speeding tickets.
So instead I ordered the valve steam seals its a kit for $35 and thttp://www.partsforimports.net/ its the local import store in my town.
I also found out that the other major parts store for all the generic stuff has the adapter for the piston to hook up to the air compressor, they also have the spring compressor and the spring holder remover. This is gonna be really interesting I will give you guys updates and some pictures. thanks for everything
![action](https://mbworld.org/forums/images/smilies/action1.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
1 Post
95' AMG SeeThreeSix
I also found out that the other major parts store for all the generic stuff has the adapter for the piston to hook up to the air compressor, they also have the spring compressor and the spring holder remover. This is gonna be really interesting I will give you guys updates and some pictures. thanks for everything![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Be sure to document your progress, take pictures and label EVERYTHING. When in doubt post a question here and on the mercedesshop.com forums, there are some extremely knowledgeable guys on there! It'll be nice to have another resource for future W124 DIYers on valve stem seal replacement. Good luck my friend.
$11.60
at www.autohausaz.com complete set of seals.
http://www.autohausaz.com/search/pro...m%20Seal%20Set
racepages.com oe cats,splice it in,after you repair the oil issue.
good luck.
good luck.
well im about half way with the replacement, its actually really easy except for loosing those small parts down the whole of doom ( where the oil goes back to then engine) but im scared because these valve steam seals are in pretty good condition i hope its not the rings...
As far as those oil return holes go I cut tubing that would fill the hole and put appropriate size screws in the top of each piece of tubing to serve as stoppers for each hole.
It almost certainly is the seals. The old ones are probably stiffer and less pliable.
Make sure you put the exhaust seals on the exhaust valves and the intake seals on the intake valves, they are different.
1 Post
95' AMG SeeThreeSix
of course hears pictures taken with my cell phone, my compression is 160 psi now
![](http://i76.photobucket.com/albums/j33/pmally2006/downsized_1102081033.jpg)
![](http://i76.photobucket.com/albums/j33/pmally2006/1107081944.jpg)
![](http://i76.photobucket.com/albums/j33/pmally2006/1105081824.jpg)
well i finished the repair, put some new spark plugs in it, it has an incredible amount of power now but all the engine oil leaked out when i took it on a test drive, I don't know where the hell its coming from i raced the car around and when i got home it was almost out of oil.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
well it looks like rings are bad its still burning oil
so if anyone wants the car im selling it for $1000 it has nice amg rims with new tires the car is preaty nice Ive replaced just about everything. I'm going to buy a Honda im sick of these cars braking down on me all the time.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
1 Post
95' AMG SeeThreeSix
well i finished the repair, put some new spark plugs in it, it has an incredible amount of power now but all the engine oil leaked out when i took it on a test drive, I don't know where the hell its coming from i raced the car around and when i got home it was almost out of oil.![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
1995 E320
I don't think i understood much of this. I'm still trying to soak all these in so that when it's time for my car to go bad, i'll know what signs to look for.
I also have the same concern as appatula. Does your car create lots of smoke? are you leaking oil? also, is your coolant reservoir clear? meaning, do you see oil in there? I'm a bit puzzled as to where the oil dissapears to?
1989 300E
300TE / 300E / 300CE
BTW, that's a hell of a nice camera phone and how did you get such large pics posted?
I acquired a 1989 300ce with 120,000 miles on it last December. I didn’t know the car had an extreme drinking problem when I bought it. It’s going through a quart of synthetic oil around 200 miles. The obvious diagnosis would be a new set of Valve Stem Seals but it doesn’t have all symptoms you would expect to see with bad seals.
I haven’t noticed any smoke coming out the back, it passed CA smog a month ago, there’s no oil on the tip of the tail pipe and no exhaust smoke residue on the paint. The car is not leaking motor oil and there is no oil in the water.
The only solid symptom I’ve noticed that points to bad valve stem seals is the sparkplugs. The plugs that were in the car were caked with gunk and wet with oil. I changed the plugs and rechecked them after I drove 30 miles and the plugs were wet and smelled like burnt oil and gas i.e. rich. Also the exhaust smells rich to me
I’m going to do a couple of thing to better pin-point the diagnosis. I’m going to have a friend follow me on the freeway to find out if it’s blowing smoke I can't see at hwy speeds. I’m also going to check the rings with a compression test. Can anyone suggest any other simple test I can do to diagnose my oil-oholic car before I dig into the motor?
Thank you,
Thank you,
