Key tumbler
Old Dec 2, 2008 | 07:43 PM
Zytek_Fan's Avatar
1992 300E
Key tumbler
How do you pull the key tumbler out?
Mine is a goner, so I can't even start my car, hell, even putting the key in is a pain
Old Dec 2, 2008 | 07:54 PM
Television's Avatar
CL500 216
You have to do it with the key turned to key1 or the steering lock will fire,,send me a PM with your Email address and I will send you a paper on how to do it
Old Dec 2, 2008 | 09:15 PM
spmbass's Avatar
1987 300E
can you send a copy to spmbass@aol.com i need to put my old one back in i cant get a key for my new one with out the vin
Old Dec 3, 2008 | 12:51 AM
Zytek_Fan's Avatar
1992 300E
I hope I can get it fixed, because the repair cost if the steering lock has to be drilled is $600 - $800
Old Dec 3, 2008 | 01:15 AM
ohlord's Avatar
You need
the tumbler picks and the diy is on mercedesshop.com use their search function.Most every year and model is covered.do not force anything
Old Dec 3, 2008 | 04:22 AM
Television's Avatar
CL500 216
MB dealers have special barrel to loan out while the new one is on order
Paper sent via Email
Old Dec 4, 2008 | 02:24 AM
Zytek_Fan's Avatar
1992 300E
Let's say you buy a tumbler with key off of eBay.
Would it work fine?
Old Dec 4, 2008 | 06:33 PM
Zytek_Fan's Avatar
1992 300E
So, we can't get the key to turn at all
Old Dec 4, 2008 | 10:23 PM
Zytek_Fan's Avatar
1992 300E
Is there any kind of tool you can use to force the tumbler into key position 1 so you can pull it out?
Old Dec 5, 2008 | 12:30 AM
Federic0W124's Avatar
1992 400E
I used pliers to force the key to turn into position 1.
do so at your own risk.
Old Dec 5, 2008 | 01:32 AM
Zytek_Fan's Avatar
1992 300E
We're gonna see if the locksmith can do anything about it.
Old Dec 5, 2008 | 07:20 PM
Zytek_Fan's Avatar
1992 300E
So, the locksmiths in town won't even touch it.
Local euro garage quoted us $500 for the complete service, which includes new steering lock cylinder, key tumbler, and keys.
It feels like the key goes in fine, but the steering lock won't disengage
Old Dec 6, 2008 | 02:10 PM
White_Knuckles's Avatar
1994 E320 Dragon Wagon
You can buy a new key/lock set for around $60. They ship with two keys. A factory matched key set (shipped from Germany) was too spendy for me. I used a second key ring on my main key ring so the ignition key drops lowest for easy ID.
I tried a method where after inserting the key you press a vibrating sander on the back of the key while, with a 6" crescent wrench, you apply slight rotation. I gave the thing a shot of WD-40 first but not sure it helps. The sander dances the tumbler pins like crazy, as you roll rotation on and off the core releases and moves to Pos 1. Took about 10 minutes of "sanding".
Don't try moving it back, immediately pull the core. Getting the key back out can be done later using the same method in a vise.
Old Dec 6, 2008 | 05:49 PM
Zytek_Fan's Avatar
1992 300E
Can you describe exactly what you did?
Old Dec 7, 2008 | 02:35 PM
You take a basic orbital or vertical 110V, home, hand sander and remove the sand paper. Any cheap (under $30) finish sander will work. Try all keys you have, starting with the least worn.
Get a grip on the key, close to the switch using a small crescent wrench or needle nose pliers with one hand. While pressing the sander's foam backing plate against the back of the key in your other hand, gently rock and rotate the key direction toward position 1.
The wrench or pliers are not for leverage, it's to control the key underneath the sander that blocks your view. Vibrations are transmitted through the key and cause the inner lock pins to jump around randomly. After some "buzzing" the lock will release and rotate. An assistant may have to rock the steering wheel back and fourth as your wheel is also locked. You can try doing this without the sander by aggressively jacking the key around while rotating. Remember to move the wheel back and forth while wiggling the key. WD-40 shot into the lock is to flush out old grease and dirt.
Once it rolls to pos. 1 - STOP. I tried the full key range to see if it released and it stuck again. Once the lock is out, pull your neg. battery cable if worried about batt. drain. You need to recover the outer ring which won't come off with the key inserted. You can place the lock assembly in a vise and repeat the procedure or cut the key off.
Old Dec 7, 2008 | 07:33 PM
Television's Avatar
CL500 216
The last guy that I helped it took him 3 weeks trying every day, then it turned.
The vibration idea is good squirt some silicon or PTFE (better) into the lock and onto the key
Old Dec 8, 2008 | 12:13 AM
Zytek_Fan's Avatar
1992 300E
Okay thanks.
We're going to try that tomorrow after my dad gets off work.
Someone on another board told me jacking up the front might help, so I'm going to try that.
Old Dec 8, 2008 | 07:11 PM
Zytek_Fan's Avatar
1992 300E
Will this kit work?
http://cgi.ebay.com/ebaymotors/Dash-...mZ170278680194
Old Dec 8, 2008 | 08:26 PM
Do some more research bro. The only thing needed are two of the rods or the "V" shaped wire depending on car model. Have you read the removal procedure the guy suggested a few posts back? Ya stick the release wire(s) in each side of the key switch and pop... out she comes.
Many guys just make them out of wire a bit smaller than coat hanger gauge. I borrowed the tool from a local shop in Spokane, it was just bent wire, not a purchased tool. I think MB sells the real one for $5.00
Not sure you'll need the rest of the kit you posted. Jacking up the nose is strange but who knows???
Try "loading" the steering wheel gently as if you're turning left. Hold the wheel against the lock point while jimmying the key. I said move the wheel back and forth but I now remember simply loading it worked. You must have experienced this before in cars when the ignition key won't turn and you mess with the wheel to release.
Old Dec 8, 2008 | 08:36 PM
Zytek_Fan's Avatar
1992 300E
Do some more research bro. The only thing needed are two of the rods with bent tips. Have you read the removal procedure? Ya stick 'em in each side of the key switch, rotate and pop... out she comes.
Many guys just make them out of wire a bit smaller than coat hanger gauge. I borrowed a pair from a local shop in Spokane. I think MB sells them for $5.00
Not sure what all the rest of the kit you posted is for. Jacking up the nose is strange but who knows???
I was just wondering if the kit was worth getting.
When my dad is working nights, we'll work on the car after school.
I'm hoping to God I can get it working.
Old Dec 8, 2008 | 08:41 PM
Where in ID are you? Near Spokane? You can do this, it just takes voodoo magic and patience.
Old Dec 8, 2008 | 09:11 PM
Zytek_Fan's Avatar
1992 300E
I'm about an hour and a half from Spokane.
I talked to the guys at Lithia, but they wanted $600
Old Dec 8, 2008 | 09:36 PM
Lighthouse Import Auto Parts in Spokane offers good deals on parts. I use autohausaz.com a lot, they're excellent with prices and shipping. Ebay for $$ parts is scary.
Mercedes of Spokane is crazy expensive. There's a couple of good indi-shops over here. I've talked to one about the key thing when mine was stuck. He's only heard of the drilling needed in rare cases.
Good luck!
Old Dec 8, 2008 | 11:59 PM
Zytek_Fan's Avatar
1992 300E
Good luck!
I emailed European Autohaus to see how much it'd be with them and if they have any ideas on what else I could do myself. They're recommended by Northwest BMW Club as being a great garage, so I'm hoping for something good.
Thanks for the link. Great prices.
Old Dec 28, 2008 | 06:20 PM
Zytek_Fan's Avatar
1992 300E
Well, after the doors were frozen shut for 3 weeks, we finally got to try the sander.
The tumblers are free, but when it hits key position 1, it's stuck, so the cylinder is definitely not disengaging.
Can someone post the directions on how to open the dash and cut the steering lock cylinder, please?
