Mounting fog lights on stock bumper?
I really love the bodykit, but its just not high on my priority list right now, but a set of fog lights totally would! I just LOVE the way low down fog lights look.
So...
1) Would it be possible?
If so,
2) where would I get a set that should work?
3) Any links on how to connect it? Would it simply wire up in place of the fog lamps in the headlights?
4) Does MTEC sell fog bulbs to match my regular beam or would I just match the (rating?) (4,350K) using any quality brand?
So...
If so,
Look at Zorro's car...if I recall he mounted two small round lights on either side.
Wiring is easy....take a power feed from the stock fog and wire it to a relay coil.
The other side of the coil goes to ground.
Take a new power feed from wherever you can find it in the fuse box, run it through an inline fuse and then to the new lights.
The other side of the lights goes to ground.
This way when you pull out the fog light switch you'll have both the stock and new ones illuminiated.
I am also curious to see if anyone has done this. Ive noticed someone on this boards' car has cutouts in his stock bumper, but no fog lights.
Now if I could just remember who that was....
I was considering it with the stock bumper, even made a template.
If I recall you could fit a maximum of about a 2.75" round light in the widest part of the opening.
Gave it up when I installed the Wald knockoff as the location was where my air intake duct is to my filter box for the turbos.
I still have to cut the openings a bit bigger to allow the outer fogs to show completely...that will get done whenever I have the chance to re-spray my front end....boooourns to rock chips.
Some information can be found here:
http://www.kin.az/tumanki.htm
And my friend made it in such way:
And then:
