Look what i got for free....
or will). Well the graduation gift has some problem
. The tranny wont shift past 2200 RPM,
weak in reverse (it engages, but if you suddently hit the accelearator pedel, it revs then it moves back.
Highlight dose not work, when i pull it the lever nothing happnes, but if i push the lever only the headlight turns off.
It has a start problem, when cold or after driven and let sit for 20 mins, it takes some crank to get it to start. When i replace the spark plug i saw quite a puddle of oil in the spark plug chamber, someone told me its was the headgasket problem.
The engine runs SMOOTH, I read somewhere that these W124 has some wire harness problems lucky i saw a tag that said "delphi" and had FD and the part number i knew i had a new wire harness replaced by mercedes dealership, even my indi mech said its has a replacement. Lucky that E320 was not equipted with ARS, I know many of you would rather take the ARS because it has more torque
... O i almost forgot to introduce my self, I live in Oklahoma, occupation is working in a hospital as a CNA
, And i we own a 300SDL, 300SD and the E320
....ENVY ON
As for the cold/warm start problem, could be the fuel filter or accumulator. I would start by checking the fuel pressure if possible and see if after 30mins the pressure has dropped below 3bar.
Oil on the plugs is not a head gasket problem -- It is either the mixture being set way too rich, bad valve guides/valve stem seals.
How many miles on the car? Do you have any history on anything other than the wiring harness?
First thing I would do though is get a compression and leakdown test done so you have a baseline to start with.
Just got a small rough idle issue with the wagon and the 260E is going to pass its smog tomorrow
Maybe then I can have two running 124's.
The only real way to test it is to cut the exhaust pipe right before the cat and if it runs better then you know the cat is blocked.
It is hard to say though...are you sure it is the transmission that won't go over 2200rpm, or is the engine not going over 2200rpm? If its the later, then its possible the cat is the cause due to backpressure.
Good to hear they were not covered in oil. If it happens again, maybe consider running a little heavier oil like 20-50.
As to the Torque Convertor, I believe there is an RPM limit when you load the torque convertor in drive with the brake on.
From what I have read, doing this is bad for the transmission in general.
But as to the RPM's, don't quote me on it, but transmissions are limited to like 2200rpm depending on the car (some higher some lower) when you do a torque test by holding the brake in drive and accelerating.
I don't know almost anything about transmissions so I can't really help you in regards to that. I would recommend finding a good independent Mercedes Benz Indie and having him look over the car and tell you what the problem is.
Considering you got the car for free, I wouldn't personally feel bad spending $1700 on the transmission. The car otherwise isn't worth a whole lot. Once that is fixed you should have an awesome ride
, I was wanting to know when your reach at 3200 RPM do you hear a sound diffrence and a suddent shift in sound and little sport like rumble in the engine, i know those are the variable intake valve, i just want to know is that suppose to happen, i thought its suppose to be smoothe all the way.
