big brakes...
Old Jun 24, 2009 | 09:09 PM
xargos's Avatar
230e w124
Question big brakes...
hey anyone know if is posible to fit a big brake kit from other kind of mercedes into a w124 chasis?
In the market I found a lot of big brakes kit for mercedes, but for the 124 is totally different history... maybe from clk, or slk will fit with a little modification into it, some advices?
Old Jun 24, 2009 | 10:41 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Contact Racetechnologies.com. they are Brembo's big brake master distributor for the USA. They are very friendly would be able to answer all your big brake questions.
Old Jun 24, 2009 | 10:49 PM
xargos's Avatar
230e w124
thansk! i got it!
Old Jun 24, 2009 | 11:33 PM
ps2cho's Avatar
E
Be prepared to pay the price for the W124 Brembo Brakes. No doubt I bet they are freakin awesome though!
Old Jun 25, 2009 | 01:30 AM
ZedStyle's Avatar
Youngtimer
not sure a 230e would ever really need a BBK though, unless you've pepped it up a bit... personally i would spend the loot on something else for it...!
Old Jun 25, 2009 | 01:57 AM
xargos's Avatar
230e w124
i put im my 230e a v8 engine, and thats made tha car a little fast than the original car, and heavier... thats a reason...
so I put my question here to share the knowlege of the people, is good to hear what think other people! and take a good/cost best deal...
Old Jun 25, 2009 | 03:53 AM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Look into r129 SL500/600 brakes.
Old Jun 25, 2009 | 11:31 AM
ZedStyle's Avatar
Youngtimer
yup, that counts as 'pepped up'...!
maybe you can find some 500E brakes? I think chris pham managed to get some AMG brakes on his car, or at least he was in the process at some point... maybe he can help with options
Old Jun 25, 2009 | 06:17 PM
greasybenz's Avatar
W203 C32 AMG, W124 E300D
AMG/Sport (brembo) brakes off the W203 C32, C55, or any C class with the sport package will work but youll need wider offset wheels to clear the beefy calipers.
They arent the best but unless your pushing over 350hp to the wheels you wont need much more stopping power.
IMHO I dont see the purpose of the bigger brakes on any W124 that isnt pushing over 300hp at the crank, but thats just me.
Old Jun 26, 2009 | 12:34 AM
xargos's Avatar
230e w124
ok, thanks... that´s the point, I want to hear the peolple... right now the engine runs like 300 hosepower, and I fell the brakes so hot... even a little trip around 4 km, for that reason i think the original brakes are over capacity.
I did a revision today at all is in perfect condition, brake pads, and hand brake are properly adjusted....
maybe i can use the same brake system but using a better rotors? more vented or slotted?
and thanks people!
Old Jun 26, 2009 | 04:51 AM
cap'n jasper's Avatar
W124
Are you saying you're using the standard 230E brakes with 300bhp?
No wonder they get hot! they're single piston calipers with solid rotors
Get some vented discs and twin piston calipers from a 320 and you'll be good to go. There should be plenty of calipers in breaker's yards and the discs/pads are cheap. 500E/SL calipers will also fit but are more expensive. Depends what you can get at the breaker's I suppose.
