E420 Painful lesson good ending
did the evac and recharge.... car acted exactly the same. Time to troubleshoot. Jumped pressure switch and temperature switch.... both checked out......
At this point I realized that the electric fans would only come on "high speed". This forum has taught me that the A/C controls the "low speed" setting.... It did not ever come on low speed..... checked Low Speed relay.... bammm!!! found it - blown fuse.... now I get low speed fans almost immediately when engaging ac..... no mods to my system so something still is amiss. I checked the cabin temps and while it improved enough to be okay, it still was not as cold at idle as last year..... but then I noticed it...... my fan..... seemed to be spinning somewhat slow even when it was 97degrees out and the low speed fans where engaged. rechecked with hot engine temp... still spinning slowly.... the clutch......it was bad also.....
SIDE NOTE: with the low speed fan out, fan clutch out, 100 degree temps in houston.....THE DARN CAR STILL RUNNING AT 90C..... never ran hot - never ran high in the range... A/C cooled great when moving.. WHAT A CAR !!!
OKAY NOW THE PROBLEM..... fan clutch $450- 650 bucks..... so I purchased one that was only $150 from a web site. I asked them repeatedly to give me data on the cars it would fit - My E420 was in the list. bought it... But questioned the deeepppp discount...
during my reassembly, I was fitting the center bolt on the clutch... I was tightening the bolt, and, when it started to get really tight I noticed the clutch was still quite loose. I shrugged and figured I needed to get it at least tight before I used the torque wrench to get the required 45Nm tightening. I cranked on it a bit more and SNAP!!!!!... bolt broken.... removed clutch... bolt broken deep within bearing.... sucked.. after 5+ hours of attempts to remove a bolt buried a 1/2 inch within the socket, i gave up.... priced the bearing bracket....... $450-$650 dollars also... I salvage purchased it for $125.
replaced bearing support bracket..... started again on center bolt... got to same point...tight bolt - loose clutch.. brain says "stop something else is wrong here". I took the bolt out and grabbed the old clutch....
stuck the bolt into each one.... the new clutch allowed a full 1/2 inch further bolt protrusion...... THE CLUTCHES WHERE DIFFERENT THICKNESS - BY A 1/2 INCH...... I called the parts supplier, I told them I fubar'd a $500 bracket due to the differences in parts...... the reply " our parts are to be installed by professional repair technicians"..... or some such crap....
THE SOLUTION..... I first ordered a bolt from MB dealer.... these bolt are not normal head configuration due to tight install situation......then I cut 1/2" from the bolt.... thank you AGAIN dremel...... (put the new bolt away for possible furtue use if this doesnt work) I Installed everything.....
I was hoping that the clutch I installed performed properly over the temperature ranges..... wellllllll......... it actually over performs. maybe someone can offer an explanation
I can not get the temperature up to above 80-82c for any extended period... maybe a minute.... I drove all kids of nutty ways to see if it would go higher.... it does not.... I made my normal 350 mile trip to houston last night... 80c all the way..... gas mileage - identicle to before..... A/C needed a little freon due to cooler condenser temp causing lower a/c pressures... A/C cold at idle and all speeds...
The clutch appears to do the job and then some.... for only 150$ and a few hours of frustration and a junkyard bearing bracket... and this is texas and louisiana....can you say "HOT !!!!!!!!!!!"
low speed is intermitent which is okay....... high speed has yet to be triggered while driving with new clutch...
You can turn the on by holding both fan a/c buttons at the same time for 10sec to make sure they work.
Your E420 runs about 10 cooler than man. Then again. I'm running water only in the expansion tank - perhaps thats why?
I've been considering running dual or a single big electric fan and replacing the current. Good idea or should I skip it? I want to get the car running as cool as possible.
Also, A friend of mine said $350-400ish installed for the electric fan setup.
Part NO. : W0133-1597469
claims to fit 1994-95 W124 E420 (only if you shorten center bolt - and it has different temp characteristics - beneficial at present)
I got stuck in rediculous traffic here on the cape today. Had to blast the heat (5 min. off, 5 min. on) for a good 45 minutes in 85-90 degree weather.
. The clutch is on, I had to fab a little cylindrical piece out of a bolt in order to lock the pulley into place while I loosened the 8mm allen bolt out (1986 300E M103). I was not joking about slamming my hand into the fins, they were just barely spinning with the engine at idle, no torque at all. When I started her up with the new fan clutch, well, lets say that I'm not going to even think about putting my hand near there! The fan really pushes air now, night and day difference. I will report back with before and after temps. Note: UROPARTS brand www.uroparts.com part # 103 200 0422
