W124(EMERGENCY!!)
Old Aug 4, 2009 | 12:25 PM
steven07's Avatar
W124 230E,W220 s350,toyota landcruiser.
W124(EMERGENCY!!)
Hi guys i need really your help.
i will go buy alloy wheels for my w124 tomorrow.So,i need a quick reply.
FRONT:7.5X17(225/45-17)ET35
REAR:7.5X17(245/40-17)ET35
Backspacing: 5.66"
Bolt Pattern: 5-112
will they fit on my w124?
thanks a lot,
steven
Old Aug 4, 2009 | 12:38 PM
CDP's Avatar
CDP
W124's
Why 245's in the rear of a 7.5"?
Go with a 225 in the rear and front.
Old Aug 4, 2009 | 12:42 PM
steven07's Avatar
will 225 cause rubbing and cause handling problems?
thanks,
steven
Old Aug 4, 2009 | 01:03 PM
steven07's Avatar
215/45 is also available.which one is better 225 or 215?
reply plz...
thnx
steven
Old Aug 4, 2009 | 01:10 PM
ZedStyle's Avatar
Youngtimer
215 will pretty much guarantee no rubbing, with 225 you might get some, i think
Old Aug 4, 2009 | 02:41 PM
ps2cho's Avatar
E
I have zero rubbing with 225/45/17. I am actually gonna try 235/45/17 once my tires wear out. I recommend 225 though.
Old Aug 4, 2009 | 02:46 PM
YNVDIZW124's Avatar
lots of cars
Wider is always better but I run 225 on the front too. No on 245 on a 7.5" rim
Old Aug 5, 2009 | 02:03 AM
steven07's Avatar
will this be good?
FRONT:7.5X17(215/45-17)Et 35
AND
REAR:7.5X17(225/45-17)ET35
thanks a lot,
STEVEN
Old Aug 5, 2009 | 11:21 AM
ZedStyle's Avatar
Youngtimer
if you go with that, your fronts and rears will have slightly different diameters/circumferences, i.e. the rears will be slightly larger around than the fronts. also, you wont be able to rotate your tires easily, which doesn't seem worth it if your wheels are not staggered.
Old Aug 5, 2009 | 01:17 PM
steven07's Avatar
Hi guys,
will these fit my w124 230E
thanks a lot.
17x8
$235 (each)
Offset: +35mm
Backspacing: 5.90"
Bolt Pattern: 5-112
Rec. Tire Size: 215/45-17
Weight: 21.5lbs.
Old Aug 5, 2009 | 01:28 PM
appatula's Avatar
95' AMG SeeThreeSix
This is ridiculous.....
Old Aug 5, 2009 | 01:35 PM
steven07's Avatar
what about this one?
17x8
$263 (each)
Offset: 35mm
Backspacing: 5.94"
Bolt Pattern: 5-112
Weight: 16.7lbs.
Old Aug 5, 2009 | 03:34 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Tomorrow has past, it's now today...what are you waiting for ????
Buy them before they are gone....
Pull the trigger !!!!
Old Aug 5, 2009 | 05:48 PM
CDP's Avatar
CDP
W124's
DAMN n00b make up your mind already. and stop posting new threads.
Old Aug 5, 2009 | 09:32 PM
ZorroAMG's Avatar
Enzo, my Benzo
This is like ChrisDPham back in 2005/6 when he was choosing headlights hahahaha
Old Aug 5, 2009 | 10:57 PM
CDP's Avatar
CDP
W124's
and it's 2005.
