Is this a bad wheel bearing?
1994 e320 sedan
Car (steering wheel) vibrates pretty bad on a freeway after reach a certain speed.
I checked the wheel bearing. There is very minimum play, but I can hear knocking noise.
Do I need a new bearing?
http://www.youtube.com/watch?v=FvStGDMwi_M
1994 e320 sedan
Oh, I also can hear metal rubbing noise front of the car when car is in motion...which means bad bearing correct?
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
If your steering wheel vibrates first replace your steering damper. Take ur wheel off and put a pry bar between ur suspension and ur ball joint. and pry if it clicks its bad. Look on psycho link he explains it good
Check the dust shields on the brakes and the backing plate. Make sure it isn't rubbing on the wheel rim or disc. Also, a stone could be stuck in the brake.
Depends on the day
Before doing anything, are your tires properly balanced? Lugs all seated securely and torqued to 80ft lbs?
Then proceed with what others have mentioned. 2 prime suspects are wheel bearing and ball joint.
1994 e320 sedan
I don't know whether tires are properly balanced or not.
Yeah, easy thing first, I will take my car to a shop and ask for balancing them. Lugs are tight, but I will use a torque wrench to tighten them.
If above those methods don't work, then I will go for sterring damper. Psycho link? Are you talking about a member?
91 MB 300CE w/5 speed
check the wheel to see if it had a weight that has fallin off, there usually will be some remnants of one being there if it has came fallen off, check the inside area of the wheel too.
the clunking sounds pretty normal, somewhat usaully you will hear more top to bottom then side to side because the top to bottom is forced by the springs and side to side relaxes with the steering.
Bad earings will usually provide a nice noticable howling noise if they are failing.
Also, take the wheel off and try that movement on the rotor, that will point to where the noise is coming from.
95' E320 Wagon (gave to father) 15' VW TDI Wagon, 05' X3, 97' F150, 99' Buell S3
Could be a number of things. Those mentioned, as well as tie rod ends, and any of the many components that make up these complicated front suspensions. Get under it and look and feel every piece for free play. A fresh steering dampener would calm down any play in the system, but not really correct another potential problem. Bad wheel bearing would be noticed with the front jacked up and slowly turn each wheel while carefully listening for any grinding noise. It might be easier to discover with the wheel off.
d
d
1988 300ce
im having the same problem, my steering wheel vibrate when im going 55+ mph (freeway) it start happening since i changed my front suspension, is this because i did something wrong when i change the struts or something else? no sounds just vibrate.
you are right , this is the most common problem , with unproper balance of the wheels,or maybe you have a bent rim, try driving the car 10,15 miles over the speed it starts vibrating, if it is one of those usually goes away
