500E WITH 2005 E55 MOTOR
I tought that was the expensive part of a swap
This is all of course after you get it in the engine bay. You will probably have to fabricate engine mounts. If you get it done it will go like stink though. I would have to say though that for the money and time I would just supercharge your engine or get another one to build. The early closed deck m119 can handle a lot of power. Put standalone injection on the m119 and a supercharger and go like hell.
Where did you get the 55k motor and trans from by the way?
If you already have the motor go for it... This is one of those projects that will never get finished though.. Unless you are one of those few people that pulls amazing stuff like this out of your a$$... lol
As far as the stand alone??? what kind are you talking about?
i know it would be easier in a 04 e500! i have one. but i dont want to do that! i just think that motor in a 500e body would look very nice! i have the time to sort it out!
Please direct your comments specifically to ChrisDpham.
I agree it was snide and not necessary.
However, you did ask for opinions, and the other people did reply honestly for your benefit.
They called upon their experience to guide you as to whether you would find the project worth the effort.
Perhaps you did not like their answers, or felt they were trying to discourage you, but they were NOT criticizing you.
I wish you well, if you decide to go ahead with this. Please let us know how it turns out.
To go standalone injection would be much easier. You could use Electromotive, AEM, Motec, etc for fuel injection. Use someone who has 60-2 teeth crank technology as it is the same as Mercedes. For transmission control you can pretty much only use the Powertrain Control Solutions tcu which I can help you with. You can get a shifter out of a early 722.6 equipped w202 or w129. It is a direct bolt in and will only require shortening the shift linkage rod and wiring. All the existing speed sensors on the car would work.
This is of course after you get th engine in the car. I am not 100% that it will fit with the existing crossmember. The 55k motor has a funny oil pan. There is also the issue of air conditioning if you still want it. You would have to make another mounting bracket for your original a/c compressor. The one on the 55k will not work with your climate control at all. But the only way to find out is pull your engine out and try sticking it in the hole.
If it doesn't workout then at least you still have an unmolested 124.036
I wonder how the stock suspension would handle something like that...
A 55 driveline in a w124 is probably something we've all dreamed of at some point, but the epic amount of work to set everything up such that the computers think youre actually driving a 55, and fit it in the engine bay, deter most of us at some point.
Good luck, if you go this route. Anything can be done with enough money and knowhow.
