400e brake options
Old Mar 3, 2010 | 08:58 PM
ocpanther's Avatar
1989 300E
Do you know how those calipers line up with the 500E ones? Just curious if the 400 & 500 are the same or if it would be better to chase down the 500E parts if someone was going to make a major switch over. Once you are into lower control arms, its not much more to do sway bars and springs. At least thats what made me think about it.
ps2cho - I did read you said it needed brakes anyway ... it just didn't sink in. Now that makes much more sense if youre already going to tear it apart to replace the pads and rotos.
Old Mar 3, 2010 | 09:37 PM
ps2cho's Avatar
E
I will be lowering the car too...so I will probably do everything at once and save on the time. Seeing as the springs will be off the LCA shouldn't be difficult. I am keeping my eyes open for a sway bar off a wagon as they are the sportline one.
500E Calipers + Rotors are bigger than 400E. I believe it goes 300E -> 400E -> SL600 -> 500E -> Brembo.........Correct me if I am wrong.
Old Mar 10, 2010 | 01:47 AM
salvine's Avatar
Mercedes-Benz 500E
You guys just need to buy these!
https://mbworld.org/forums/suspensio...-calipers.html
Old Mar 13, 2010 | 04:30 PM
ps2cho's Avatar
E
Alrighty...Got myself a sportline swaybar @ junkyard today. Found some LCA's, but it wasn't 50% off, so I decided to wait.
Gonna need the sportline swaybar bushings. This car is gonna be so sporty once I get the brakes and suspension all dialed in. Can't wait!
Old Mar 13, 2010 | 05:14 PM
ocpanther's Avatar
1989 300E
I went today too ... I was trying to drop you a message as there was a 320 there, but as I was checking it out they carted it away on the forklift.
Old Mar 13, 2010 | 06:36 PM
pifcat2's Avatar
300TE / 300E / 300CE
27.5mm from a wagon? Seems like it wouldn't make much of a difference since stock is 1mm smaller. Limos are 2mm larger.
They want $25 ea for a LCA but I'd have to replace all the bushings and ball joint to do the conversion...
Old Mar 14, 2010 | 03:24 AM
  #32
Saijin_Naib's Avatar
1990 300ce 24v I6
Ps2cho, I put the Limo front bar in my coupe and so far it is AMAZING. Rear will follow shortly, ran outta cash
Old Mar 14, 2010 | 03:20 PM
  #33
ps2cho's Avatar
E
It is noticeably thicker and they only charged me $19.99. I wanted to upgrade and put the sportline bushings on it as well.
I may do the rear swaybar at a later date. I hear its a lot more involved?
Old Mar 14, 2010 | 03:58 PM
  #34
pifcat2's Avatar
The larger are better but I'm just commenting on how close the diameters (measured at middle) are:
  • Stock 300E 26.5mm
  • Stock E420 26.5mm
  • Sportline 300E, 300CE 27.5mm
  • Stock E300 Cabriolets 27.5mm
  • Stock 300TE all wagons 27.5mm
  • Sportline E300 Cab or Limo 28.5mm
these numbers are from I believe AMGDave's spreadsheet
You have to drop the rear susp a few inches to get the swaybar in. Wagons have an SLS bracket to fit as well.
Old Mar 14, 2010 | 10:07 PM
  #35
ps2cho's Avatar
E
^ True. The outer diameter is 4mm thicker though. For $20 its worth it
Old Mar 14, 2010 | 11:41 PM
  #36
pifcat2's Avatar
4mm? according to the chart only AMG and RENNTech had 30mm and 32mm respectively...
Old Mar 14, 2010 | 11:55 PM
  #37
ps2cho's Avatar
E
Inner diameter
My inner is 27.5 vs 26.5mm, outer is 22mm vs 18mm.
http://www.w124performance.com/image...4_swaybars.pdf
Old Mar 26, 2010 | 10:23 PM
  #38
ps2cho's Avatar
E
Here's a video of my Soda Blaster power!
http://www.youtube.com/watch?v=bNLPSsxY5Dc
First coat of paint...Will take some better pictures in the AM when I have all 5-6 coats on.
Old Apr 28, 2010 | 05:27 PM
  #39
ps2cho's Avatar
E
Oh sweet baby jesus
I didn't even remove the dust shield. I just bashed it until it turned from circle to flat as I desired. Clearance to dust shield covering ball joint is ~2mm.
Old Apr 28, 2010 | 05:39 PM
  #40
1990 300ce 24v I6
Wow, that soda blaster works miracles. Could you test it out on the exhaust manifold if you get a chance :P
Old Apr 28, 2010 | 06:16 PM
  #41
ps2cho's Avatar
E
It does. It also makes fine work of everything in the surrounding area too
I don't see why it wouldn't work on the exhaust manifold.
Old Apr 28, 2010 | 08:43 PM
  #42
pifcat2's Avatar
nice! any clearance issues with the stock lca's?
Old Apr 28, 2010 | 10:08 PM
  #43
ocpanther's Avatar
1989 300E
I was reading in a 4x4 posting that soda blasting has to be neutralized (as it is a base) or it creates metal degradation. Did you have to do anything to the brakes after you blasted them?
Has anyone else heard this rumor?
Old Apr 28, 2010 | 10:56 PM
  #44
ps2cho's Avatar
E
Not after I hammered the dust shield to make it flat. It is close, don't get me wrong. Probably 2mm gap. It would be ~5mm if I cut off the shield, but it seems a pain. You cannot just "remove" the shield without taking the hub off.
I'll drive with it for a while and see how it goes.
Got one side completely done today -- New Tie rod assembly, Eibach springs, Rotors + Calipers. Took quite a while unfortunately...Midway through the front left.
After a little tweaking I did manage to get the front spring out w/o removing anything else. Just gotta really push the plates as high + low as possible.
Old Apr 29, 2010 | 03:34 AM
  #45
1990 300ce 24v I6
Doubt it panther.
via Wiki
" [edit] Neutralization of acids and bases
Many laboratories keep a bottle of sodium bicarbonate powder within easy reach, because sodium bicarbonate is amphoteric, reacting with acids and bases. Furthermore, as it is relatively innocuous in most situations, there is no harm in using excess sodium bicarbonate. Lastly, sodium bicarbonate powder may be used to smother a small fire.[5]
A wide variety of applications follows from its neutralization properties, including ameliorating (improving) the effects of white phosphorus in incendiary bullets from spreading inside an afflicted soldier's wounds.[6] Sodium bicarbonate can be added as a simple solution for raising the pH balance of water (increasing total alkalinity) where high levels of chlorine (2-5 ppm) are present as in swimming pools and aquariums.[7]"
Old Apr 29, 2010 | 11:41 AM
  #46
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
You need to let me borrow that soda blaster!
Old Apr 29, 2010 | 12:36 PM
  #47
ps2cho's Avatar
E
It's just my dads compressor and a cheap attachment with a tube that goes to a bag of baking soda
The attachment:
Old Apr 29, 2010 | 03:16 PM
  #48
pifcat2's Avatar
hmmm, I thought I read the caliper interferes with the lca or tie rod. The conversion sounds simple if it's just the shield. I've removed the hub, it just takes more time. Before that I've removed the shield screws to rotate it but found it was easier to remove it. You know where to position the compressor plates after a binding it couple of times...
Old Apr 29, 2010 | 03:28 PM
  #49
ps2cho's Avatar
E
Nope. The top hits, but that is as simple as bending the shield back. The real issue is the bottom at the ball joint. You can A) Bend the shield back so it is as close to the ball joint as possible, or B) Cut a circle out of the bottom where it touches C) Remove the whole thing.
I have changed my mind and will be cutting a circle around where it hits. I don't want to remove the shield entirely because it would be redundant. Making a small incision where it touches will resolve the issue and still allow me to keep the dust shield.
The caliper touches nothing. Plenty of clearance. Here is a pic:
Old Apr 29, 2010 | 08:26 PM
  #50
ps2cho's Avatar
E
Anybody know the part # for the 400E brake pad shims? I seem to have misplaced one and I need another. The EPC does not show it for some reason....
