400e brake options
Old Apr 30, 2010 | 06:06 PM
  #51
ps2cho's Avatar
E
Looks like the dealership does not sell them separately. You must buy the pad set...
Will it be OK running without?
Old May 3, 2010 | 04:04 PM
  #52
ps2cho's Avatar
E
Got it all up and running.
DAMN this thing stops good!!
And it hasn't even broke in yet
I find no problems using stock MC!!
I guess I gotta get going on my AMG Gen I bodykit now
Old May 3, 2010 | 06:40 PM
  #53
pifcat2's Avatar
300TE / 300E / 300CE
Sounds like a great upgrade, I'm glad I didn't get rid of my calipers.
Can you tell me your rotor width next time you have your wheels off?
Old May 3, 2010 | 06:44 PM
  #54
ps2cho's Avatar
E
22mm rotor for the 92 caliper. 25mm rotors for the 93+ caliper. I have the 22mm.
Old May 3, 2010 | 06:59 PM
  #55
pifcat2's Avatar
So do I on my coupe but my slotted rotors are over 22mm and I get scraping. I may need to clean out the area behind the pads but the pads don't separate from the rotor. Did you end up w/o shims?
I have a loose pair of calipers from a 93 but they are identical to my 90 coupe so they are before the mid-year change. I'll put these on my wagon...
Old May 3, 2010 | 07:46 PM
  #56
ps2cho's Avatar
E
I had to compress the piston all the way back to fit it in, but it fit without any issues.
I used shims yes
Old May 3, 2010 | 11:18 PM
  #57
pifcat2's Avatar
I used shims yes
my rotor is 22.3mm, not sure if that's the problem
Old May 4, 2010 | 12:14 AM
  #58
ps2cho's Avatar
E
Is it aftermarket?
Old May 4, 2010 | 12:57 AM
  #59
pifcat2's Avatar
Is it aftermarket?
yes, slotted with holes
Old Jun 20, 2010 | 02:55 PM
  #60
wagmar's Avatar
1991 300e, 1989 300e
Question: Will the 25mm rotors from a 93 e320 clear the LCAs on a 1989-92 300e?
Old Jun 26, 2010 | 03:39 AM
  #61
pifcat2's Avatar
I finally noticed the min marking on the rotor edge which verify I have the 25mm wide and I need the 22mm. What disturbs me is I already measure near min thickness at 22.21 which is just enough to scrape. This may also be the difference of just clearing the ball joint on the '93+ LCA. 3mm is only 0.12" but must have some reasoning behind it. I was told another way to tell the difference between the narrow and wide caliper are the retainer, where the wider one has notches:
Attached Thumbnails 400e brake options-rbhttphandler.jpeg   400e brake options-rbhttphandler-1.jpeg
