400e brake options
Old Oct 18, 2009 | 05:31 PM
ps2cho's Avatar
E
400e brake options
I got a set of 400e brakes from the junkyard today. Do I need any diferent rotors or pad combinations?
Can't wait to paint and put them on my 260E...the rotors and pads are pretty much ready to replace.
Do you think I should get some stainless steel lines?
Old Oct 18, 2009 | 11:27 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
How many pistons does the 400 use?
Old Oct 18, 2009 | 11:46 PM
ps2cho's Avatar
E
It has 4.
I'm having to do some heavy searching over at peachparts surprisingly and it seems the early models have a problem with it touching the LCA....Some people have had success cutting the dust shield and others have not...so I am a little confused over what I should do. One way is to use the 400E or 93+ LCA and transplant them, but I don't really want all that work.
Old Oct 18, 2009 | 11:53 PM
OJ's DNA's Avatar
Tesla model S
Originally Posted by ps2cho
It has 4.
The only 400E rotors I know of that hit the lca is on lowered cars...
Old Oct 19, 2009 | 12:07 AM
JSe420's Avatar
1994 E420
Might as well get stainless steel lines if your gunna have to bleed anyway
I have some used 400e drilled rotors with about 3/4 life left on them. PM me if your interested.
Old Oct 19, 2009 | 12:21 AM
ps2cho's Avatar
E
Thanks, but I plan to buy new so I have a good baseline.
Do I need to get 400E rotors or will 300E rotors work fine? I like the look of the ATE Premium ONE's:
Old Oct 19, 2009 | 12:43 AM
1990 300ce 24v I6
If I recall correctly, you can also get the LCAs from the 90+ 300ce because they are using the LCAs from the r129.
Old Oct 19, 2009 | 04:48 AM
misabou's Avatar
E 220 Coupe E 320 Cabrio AMG E 300 Diesel
It has 4.
I don't know about LCA of 400E but I can tell you my experience.
I upgraded my E 220 brakes to 320 CE first series (which are different from E 320 and equal to 300 CE-24); these are also four-cylinder pistons fixed calipers (I don't know if 400 are exactly the same). When I first tried to install in my car I realized that dust shield and also brake disk touch the ball joint; and even if I removed completely the dust shield the play between ball joint and brake disk was extremely low: what it was in my opinion very dangerous. So I realized that LCA must be replaced. If you compare both LCA's you'll find the difference is in the ball joint. The only thing is that with new LCA ball yoint can't be replaced in case of damage.
With rear brakes the problem was the dust shield which is very difficult to replace. So I decided to cut them, as result, is like new intake!!. You only need to make a cut in the top (see photos),
A summary of what I repaced.
- Front lower control arms
- Front Dust shields
- Front Wear pad harness
- Front calipers (1-piston floating calipers by 4-piston fixed calipers)
- Front brake disks (284x22 by 295x22)
- Rear calipers (35 mm double-piston fixed calipers by 38 mm double-piston fixed calipers)
- Rear brake disks (258x9 by 278x9)
- All pads
- brake fluyd
I took all parts from the junk yard except brake disks and brake pads.
I didn't need to replace any line because are the same and I can sure all is right, as a result, and upgraded brake efficiency and cool look!!
Hope useful!!
Attached Thumbnails 400e brake options-15052008105.jpg   400e brake options-14052008095.jpg   400e brake options-15052008102.jpg
Old Oct 19, 2009 | 07:08 PM
CDP's Avatar
CDP
W124's
Buy Zimmermann rotors.
Old Oct 19, 2009 | 09:48 PM
ps2cho's Avatar
E
I've heard good things about them, but I'm afraid they will be too big/wide and not fit!
Old Oct 19, 2009 | 11:00 PM
ps2cho's Avatar
E
- All pads
- brake fluyd
Hope useful!!
Did you not replace the master cylinder as well? How is the braking without it? I have been advised to go find one...
Old Oct 20, 2009 | 01:37 AM
misabou's Avatar
^ No, I haven't replace master cylinder. I've been told is the same.
The breaking is much better than before. I appreciate it when comparing with driving as I used to: The result is that you need to be more smooth with the pedal to decelerate the same amount; more sensibility. And also for emergency stops brakes better. I took me about 6,000 miles to get the optimal brakes condition (When just replaced they brake bad than before as logical). You must take into account I'm a great cruiser. So, I'm very happy with results.
So my recommendation, from my experience, is to change 4 brakes to keep braking balanced. And also paint the brake disks, in the pictures you can see it from new without any protection: After having used some mounths they completely oxidizate with didn't like me at all. So I had to protect them with paint and now looks cool!
Old Nov 19, 2009 | 11:33 PM
SL-ML-C's Avatar
2000 MR-S daily driver, 1997 SL600 weekend fun, 1999 ML430 tow vehicle
you can use any 400E rotor, or any W124 E320/E420 rotor but thats it.
MC and booster, you are fine with stock, stainless lines, do it really only if you appreciate that sort of mod and have aother $80-100 to throw at it.
stock single diaphragm booster can still tear your face off, the car stops faster than anything else I own, and that is saying something.
these do wonders for W201s and W124s, I recommend for every owner.
Old Dec 19, 2009 | 05:16 PM
MercBimmerman's Avatar
97 BMW 740iL / 00 MBZ E320 4MATIC
Keep in mind that the 92 and 93 400E rotors are not the same
up to Nov 92 they made 22.4mm thickness with 8mm center vent, the upgraded (or 93 400E/94-95 E320/E420) rotors Mercedes installed 25mm with 10.5mm center vent to prevent premature warping. So if you have the newer 93 400E calipers the older style rotors will not work.
Old Dec 28, 2009 | 12:39 PM
ps2cho's Avatar
E
Almost ready to do the upgrade.
I'm not sure what year the caliper is from. How can I figure this out?
Old Dec 28, 2009 | 01:17 PM
pifcat2's Avatar
300TE / 300E / 300CE
Did you get the lca's? I just bought a new set for my wagon but should have bought the 400E/300CE type for the upgrade...
My RT sedan actually stopped very well with just quality rotors, pads, and sstl lines.
Old Dec 28, 2009 | 01:34 PM
ps2cho's Avatar
E
I decided based on other forum searches that I can do without for right now. If there are any issues I will replace them though. I'll measure the clearance once they are on.
Old Dec 29, 2009 | 04:58 AM
misabou's Avatar
I don't know if this is right or is a simple chance but is the difference I found from my experience.
The old callipers have printed numbers 39 for the left and 40 for the right as well as the name "Ate" in the outter side, that's what I painted in white. These callipers fit with 295x22 mm brake disks.
The latest callipers have not these numbers printed and fit 294x25 brake disks. (only smaller numbers as 57 in the picture)
Old Dec 29, 2009 | 09:51 PM
ps2cho's Avatar
E
Hmm interesting. I am doing some searching for pictures.
https://mbworld.org/forums/e-class-w...-calipers.html
90' 300CE has the ATE symbol.
You might be onto something...
Old Dec 30, 2009 | 04:26 AM
misabou's Avatar
Yes, the upgrade was carried out in 1992 (last months aprox).
Old Mar 3, 2010 | 06:14 PM
ps2cho's Avatar
E
Got all my parts!
Can't wait to install all this.
Old Mar 3, 2010 | 06:49 PM
ocpanther's Avatar
1989 300E
Looks like fun ... new toys to play with. Do you feel like you needed upgraded brakes? Mine are still bone stock and stop really well. Granted I just had them done a couple of months ago, but they are still really sharp.
Let us all know how this goes, I am very interested in the experiance and improvemnts gained.
Old Mar 3, 2010 | 07:04 PM
1990 300ce 24v I6
Same fluid I got
Old Mar 3, 2010 | 07:08 PM
ps2cho's Avatar
E
I've heard they are a really good upgrade. First I found the 400E Calipers @ the junkyard...then I needed to do a complete rotor + pad change anyway as my current rotors are looking tired, so I figured why not? It costs about $60 more in parts and I may run into some issues (possibly) with the lower control arms...but I think it "should" go smoothly once I just remove the dust shield completely.
Also they look *****in'
I have the rear 400E/300TE calipers, but my rears are fine right now so once they wear out I will do it. I've heard its a much more involved job because to take off the dust shields is a lot of work, so it would require either a) removing them or b) cutting them up. Both of which will take time and effort.
I went with whatever Pepboys carried. It looked fine and exceeds DOT4 so should be okay to use in non-track environments.
I was gonna get some stainless steel lines, but I thought why spend $110 on em? The 400E didn't need em...so I just bought new OEM for $10/each
Old Mar 3, 2010 | 08:20 PM
ps2cho's Avatar
E
I know it was mentioned above that lowering the car may impact it...
If so, I will have to get some 400E LCA I guess!
