Bad skipping/non-firing cyl. on my way home!
On my way home yesterday I noticed that upon accelerating the car was really jittery and lost its "torquey-ness". Note: this happened out of nowhere getting on the highway. At a stop the idle was REALLY awful and shaking the heck out of everything. When I got home I checked that all of the wires were getting spark, no dice. I pulled the spark plugs one by one this morning before work, I started pulling them from the distributor back. They all had a fair amount of crusty buildup that I wire brushed away. Then the rear plug.....by far the cruddiest one of the bunch and stunk of gasoline! Bingo! Cleaned it up and shes back to the good ole normal uneven idle
. I know that I'm in for a new headgasket soon, and I assume the crud buildup Im scraping off of these plugs is burned up coolant. I think this would make sense since that the rear plug was the worst and this is where the M103 head gaskets have a thin coolant channel known for failure, correct? All in all, this engine is such a workhorse. Not much can kill it.
.A head gasket is a definite repair in the near future. Oil is leaking from the exhaust side, rearmost part of the head. The front timing chain cover is leaking like crazy as well.....
I would definitely flush the coolant because it begins to degrade in efficiency and will turn a horrible color (although you said its fine so not bad in that department). It will also make sure your water pump's life is extended as much as possible. Make sure to use Zerex G-05. You can find it at any local NAPA store if they have it in your state, or alternatively go to the dealership -- their prices are not far off anybody else s when it comes to fluids.
Are you sure the oil leak at the exhaust side isn't coming from the valve cover gasket?
If you are ready for an oil change, you definitely want to make sure to get diesel grade oil. I have "heard" as well that it leaks less than a comparable non-diesel oil. So it may help you in that department. I have a list of good ones in the DIY sticky 2nd page. And also a proper german filter too
Here are some shots of the rear of the engine in which a good amount of oil can be seen dripping down just underneath the rear exhuast manifold, seems to be where the head and block meet? Also a picture of the famous timing chain cover leak!
What would be your next best guess? HG?
This plug has ash deposits which are light brownish deposits that are encrusted to the ground and/or center electrode. This situation is caused by the type of oil used and adding a fuel additive. This condition will cause a misfire. This can be also caused by changing oils in midstream.
Also before, when I was running Bosch resistor plugs (ALWAYS with 93 or 91 octane) and I was detonating very badly. On almost all of them the porcelin surrounding the electrode was completley GONE, cracked off. So I most likley have bits and pieces bouncing around in there still.
Excessive detonation has caused the porcelin on this plug to break away. If this engine is allowed to run, engine damage can occur. Make sure the fuel octane is high enough for the engines requirements.
That is the direction the oil travels if it is leaking. It shouldn't be splattering all the way to the back of the block in the quantities yours shows.
