AMG Gen 1 kit...
Old Feb 22, 2010 | 12:33 PM
  #51
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Originally Posted by Saijin_Naib
So, would you recommend the Extreme Dimension kit overall Ed? I've lost my front spoiler ages ago and am in the process of deciding what kit to go with to finalize the look of my car.
Also, you now own another of my all-time dream cars. The CLK63 Black and the 190e Evo II are in my Top 5.
Brett
The ED kit is reasonably price and better then average quality..
As close as one can get to an accurate replica of the GEN I
Old Feb 22, 2010 | 12:35 PM
  #52
RBYCC's Avatar
Bet you've seen it, but here it is just in case:
http://www.youtube.com/watch?v=a5_ats59rmo
Top Gear's impressions of the CLK63 AMG Black.
So, when we meet up this summer to race Ed, may I see the Black?
Old Feb 22, 2010 | 12:46 PM
  #53
RBYCC's Avatar
Originally Posted by ZorroAMG
Good for you, Ed! That's quite a car to own and I look forward to the pics!
Couldn't resist...fairly priced, Mercedes CPO until 2012. 5700 miles and a bit of provenance from the original owner..
Car is at a Merc dealer in North Carolina...weather clearing up here, hope to have it delivered by early next week lastest...
Old Feb 22, 2010 | 03:58 PM
  #54
ps2cho's Avatar
E
RBYCC, do you happen to know what material the OEM AMG Gen I items are made of?
Gotta figure this out so I can get the right material to plastic weld it.
Old Feb 22, 2010 | 09:37 PM
  #55
ZorroAMG's Avatar
Enzo, my Benzo
I'm willing to bet that it's Polyurethane like my Gen II
Old Feb 22, 2010 | 10:20 PM
  #56
CDP's Avatar
CDP
W124's
+1
Old Feb 23, 2010 | 12:05 AM
  #57
ZedStyle's Avatar
Youngtimer
i came across this coupe for sale, it has a bad tranny he says, and is asking for $2500 obo. it has an AMG kit too with a ducktail, it may or may not be worth it for someone to haggle him down to take the kit and then junk the car...
http://anjaandluis.com/#1
Old Feb 23, 2010 | 08:41 AM
  #58
RBYCC's Avatar
Like Z and Chris posted it's polyurethane...
Not sure how well it takes to plastic welding.
Looking at your damage, I would probably bond a rigid piece of whatever you find to the back of the damaged area, or as crazy as it sounds fill the void behind the damaged area with an expanding PU foam.
AMG used expanding foam to fill voids on the wheel wells of some widebodies !!!
Then use a reinforced filler ( Bondo with a chopped fiber ) to make the repair on the front.
Ed A.
Old Feb 23, 2010 | 08:46 AM
  #59
RBYCC's Avatar
The front looks GEN II without the lights installed.
Buying right and the kit is worth as much as the car !!!
Old Feb 23, 2010 | 09:35 AM
  #60
Merkey's Avatar
1984 190D
Glass fiber will not stick to PU.
Body repair shops use plastic welding... its the only way to go.
Old Feb 23, 2010 | 12:40 PM
  #61
RBYCC's Avatar
You are correct about fiberglass not sticking to urethane.
Even if you plastic weld, you may need to reinforce and fill to finish..
I was speaking about a thin flexible skim coat to fill any voids or holes left by the repair.
By the time you finish sand it's hardly visible...
Bondo used to make a two part reinforced urethane bumper repair material that could be finished..
Looks like since 3M purchased bondo, they dropped the product as 3M had a similar kit.
Old Feb 23, 2010 | 10:45 PM
  #62
BoostedCayenne's Avatar
2005 Porsche Cayenne Turbo
Originally Posted by RBYCC
The Extreme Dimension is as close as you can get to the real one as it accepts the OEM impact strips.
Rear was fine, but the area cast into the front was slightly narrow in the area of the license holder.
The stock impact strip bulged when installed on the ED part.
I have two friends who picked up very cheap W124's as DD's ..... and they are considering the ED kits.... I might even pick up a rear and sides for my W126
What is your opinion on the ED kits overall, and what was up with the front not fitting? what would it have taken to get it to fit properly, without cutting it to the OEM bumper top??
Thanks!!!
Old Feb 24, 2010 | 01:57 PM
  #63
RBYCC's Avatar
Thanks!!!
What makes the ED kit desirable is that it uses the stock impact strips.
Most other kits have the strip / bumper molded as one piece.
For whatever reason, the center section of the ED bumper was slightly narrower then the impact strip.
The stock strip wouldn't fit flush and bulged slightly.
The ED part may or may not be slightly different in another kit.
It appears that I could have reworked it, but decided to splice the stock top with the ED bottom to keep the stock mounting and interior absorber block.
Relief cuts had to be made in the top section to match the widebody flare of the front wheel arch.
The OEM top seemed easier to modify for my application.
The ED kit is good quality but has no mounting points.
You have to remove the mounting points from the stock pieces and transfer to the ED...not that difficult, but also not a straight bolt on
Old Mar 29, 2010 | 04:23 PM
  #64
ps2cho's Avatar
E
Got a quote at a local collision repair shop..$650 to fix that crack
Looks like I'll be doing it myself for sure now!
Old Mar 31, 2010 | 01:39 AM
  #65
W124Extreme's Avatar
W124 E Cabrio, 997 Porsche cabrio
Socalcarbon (albert?) said he was using bmw 740 fog lights, but I can't seem to figure out which year or model are going to fit
The 740 fogs thats used is for the ASD Gen I front bumper, not the AMG. You can see the pix of it on the site www.SoCalCarbon.com
Old Mar 31, 2010 | 01:24 PM
  #66
justinwrock's Avatar
Ducati
lol, the Bosch Fogs that fit into the bumper are the same ones used on pre facelifted E30 BMWs.
I snagged a 2 sets for both of my AMG bodykits.
Old Mar 31, 2010 | 01:25 PM
  #67
Ducati
Old Mar 31, 2010 | 05:04 PM
  #68
ps2cho's Avatar
E
Wow thanks for the tip Justin. I'll look later tonight and see if I can find them anywhere for a reasonable price.
Old Mar 31, 2010 | 09:41 PM
  #69
ps2cho's Avatar
E
I'm doing some searching...I know nothing of BMW's...What model years would be the pre-facelift?
Would this be the facelifted? So not these!
Old Mar 31, 2010 | 10:02 PM
  #70
ocpanther's Avatar
1989 300E
Should be early 80's
I think these:
http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
Old Mar 31, 2010 | 10:10 PM
  #71
ps2cho's Avatar
E
^Those were the ones I was looking at. I asked the seller to provide dimensions for me. They "look" like the same model though.
Old Mar 31, 2010 | 10:35 PM
  #72
ps2cho's Avatar
E
Just bought these!
http://cgi.ebay.com/ebaymotors/ws/eB...m=350333831188
He listed the dimensions (which I measured will fit perfect) and the price was only $70 shipped. Awesome steal
Old Mar 31, 2010 | 11:55 PM
  #73
ocpanther's Avatar
1989 300E
Awsome look!! Lets see them put together when you get them.
Old Apr 1, 2010 | 12:15 AM
  #74
Saijin_Naib's Avatar
1990 300ce 24v I6
Just bought these!
Crap, lol. I was looking at those :P
Old Apr 1, 2010 | 01:34 AM
  #75
ps2cho's Avatar
E
Ya snooze ya lose! Soon as I saw the dimensions I jumped on it. Knew some lurkers were going to steal my now potential lights to fill the hole in my bumper
If I see some others for a good price, I'll be sure to send you a PM
Once I get them I'll take some pics with em sitting in the housing...can't bolt em in yet as I am fixing the crack and still need to paint.
